abs light is on... what do i check first
Old Jul 9, 2003 | 09:37 PM
vtran8's Avatar
Default abs light is on... what do i check first
abs light just went on and i know that i need to resurface or replace my rotors..and my brake pads are fine...what else do i need to check on?
Modified by vtran8 at 6:51 AM 7/10/2003
Old Jul 9, 2003 | 11:25 PM
KingFish's Avatar
Default Re: abs light is on... what do i check first (vtran8)
I would check the brake fluid level. If it is low the ABS light will come on.
Hope that helps!
Old Jul 10, 2003 | 06:40 AM
J-Ro's Avatar
Default Re: abs light is on... what do i check first (erictegra)
ABS Wheel Sensors
Old Jul 10, 2003 | 06:51 AM
timmy8151's Avatar
If its not the abs reservoir level,then pull the ABS code from the service connector.
Old Jul 12, 2003 | 10:56 PM
vtran8's Avatar
Thanks..ill check all these and I hope i can get that light to turn off.
Old Jul 12, 2003 | 11:48 PM
Visionist's Avatar
wheres the abs service connector???
Old Jul 13, 2003 | 09:44 AM
Closer_2001's Avatar
New User
When you start the car you will hear the ABS modulator do a self-test (buzzing noise for 1-3 sec.) If the Modulator (In Right Front of engine bay w/ lines coming out of it and fluid res) does not build pressure, it may continue buzzing for 15 s. and then set the ABS light.
The rebuilt part from Acura is unfortunately $700. You can find them out of salvage cars off Ebay for less than $100.
I just bought a 94 GSR w/ this problem and will be fixing it with a part out of an 01.
Old Jul 13, 2003 | 09:05 PM
hitekper4mance's Avatar
Default Re: abs light is on... what do i check first (Closer_2001)
wtf
Old Jul 13, 2003 | 09:08 PM
AWDxBOOST's Avatar
Default Re: abs light is on... what do i check first (hitekper4mance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hitekper4mance &raquo;</TD></TR><TR><TD CLASS="quote">wtf</TD></TR></TABLE>
whats the point of this post?
check the reservoir...fill as needed...then see if its still on and post back
Old Jul 14, 2003 | 01:02 AM
vtran8's Avatar
Thanks Closer..
Thats the problem i have too...the self test goes off for about 15 seconds coming from the ABS Modulator. I hope i don't have to fork out much to get this fixed. Ill try filling the res first.
newhondaowner29
Jan 11, 2006 08:11 PM
Accord2k-Hybrid
Oct 27, 2005 09:41 AM
94~GSR
Sep 30, 2005 10:33 PM
CNSK
Apr 12, 2003 11:13 PM
redteg1
Aug 18, 2001 02:42 PM
