What parts can I buy now if I plan on getting a B16A later..?
Old Jul 9, 2003 | 09:21 PM
Gonzo_SiR's Avatar
Default What parts can I buy now if I plan on getting a B16A later..?
I have a 91 CRX Si but I'm a bit hesitant on what mods to buy, knowing I'll be swapping in a B16A in a few months. For example, can I buy an Exhaust, Intake Etc.. and keep them for when I get the B16A..?
Old Jul 9, 2003 | 09:24 PM
91civicEX's Avatar
suspension, any thing on your suspension. new crossmember so you wont have to bend your other one. wheels, tires. i dont knoiw the engine stuff so ill let someone else handle that.
Old Jul 9, 2003 | 09:34 PM
Rywire's Avatar
Default Re: What parts can I buy now if I plan on getting a B16A later..? (Gonzo_SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gonzo_SiR &raquo;</TD></TR><TR><TD CLASS="quote">I have a 91 CRX Si but I'm a bit hesitant on what mods to buy, knowing I'll be swapping in a B16A in a few months. For example, can I buy an Exhaust, Intake Etc.. and keep them for when I get the B16A..?</TD></TR></TABLE>
Yep, exhaust, intake, and cat. Dont get the header till the swap (99-00 civic si). Ryan
Old Jul 9, 2003 | 09:40 PM
Gonzo_SiR's Avatar
Default Re: What parts can I buy now if I plan on getting a B16A later..? (droppedcrxsi)
So the exhaust I get for the current stock engine in the Si will fit perfectly when I get the B16A...?
Old Jul 9, 2003 | 10:38 PM
Rywire's Avatar
yep. Ryan
Old Jul 9, 2003 | 10:50 PM
kurinto's Avatar
I personally would wait for the intake, the best one performance-wise for a swap is one for a 99-00 si, even tho you will have to do something about the battery because its in the way.
Old Jul 10, 2003 | 06:52 AM
SIRX's Avatar
don't buy anything that bolts to the engine. but as said before cat., exhaust, suspension, wheels, etc. are good
Old Jul 10, 2003 | 08:39 AM
DJ_SaNdOz's Avatar
Default Re: What parts can I buy now if I plan on getting a B16A later..? (SIRX)
If you plan on buying stuff to assist w/ rebuilding the B16 &/or general maintanance:
parts for b16:
Water Pump 19200-P30-003 94 - del sol
Head Gasket 12251-P30-014 94 - del sol
Oil Control Orfice O ring 15142-PH3-003 94 - del sol
Intake Manifold Gasket 17105-P30-004 94 - del sol
Exhaust Manifold Gasket 18115-P30-013 94 - del sol
throttle Body Gasket 16176-PR3-010 90-91 integra
Pcv valve 17130-PM6-G01 94 - del sol
Timing Belt 14400-PR3-004 94 - del sol
Alternator Belt 31110-PR3-003 94 - del sol
Tensioner 14510-P30-003 94 - del sol
Thermostat 19301-P08-305 90-91 integra / 94 del sol (same)
Connecting Pipe O rings (2) 91314-PH7-003 90-91 integra / 94 del sol (same)
Cap & Rotor Assembly 06303-PR4-000 90-91 integra
Rotor (If needed seperately) 30103-PR3-016 90-91 integra
Clutch Cable 22910-SK7-A02 90-91 integra
Throttle Cable 17910-SK7-A03 90-91 integra
Cam Seals (2) 91213-PR3-004 94 - del sol
Oil pan seal 11251-P30-004 94 - del sol
Oil Pump (comes with crank seal) 15100-PR3-024 94 - del sol
Oil Filter 15400-POH-305 94 - del sol
Oil Pick Up Gasket 15221-PW0-S01 94 - del sol
Bitch Pin Shift Linkage 91 crx si ???
Shift linkage bushing 54303-SB2-010 90-91 integra
crank seal 91212-PR3-003 94 - del sol
rear main seal 91214-PH1-004 90-91 integra / 94 del sol (same)
Valve cover grommets (8) 90442-P30-000 94 - del sol
Spark Plug O rings (4) 12342-P66-000 94 - del sol
Rubber plug for exhaust cam tranny side 94 - del sol
Spark Plugs (4) BKR6E-N11 NGK
Spark Plug Wires 32722-PR4-A01 92 - integra gsr
Upper Radiator Hose 19501-PR3-000 92 - integra gsr
Lower Radiator Hose 19502-PR4-A00 90-91 integra
Bypass Hose (Thermostat) 19508-P08-000 94 - del sol
Washer for coolant drain on block 90401-PR4-000 94 - del sol
I'm not 100% sure on the part #'s etc as this is something I compiled about a year ago when I was considering the swap, but I have a ZC not a B16 so some may possibly be off, but for the most part it should be right.
Old Jul 10, 2003 | 03:20 PM
B17ACRX's Avatar
These are things you're going to want to upgrade:
Suspension - Heavier engine = more weight up front = more understeer. Get new shocks/springs... lots of choices and combos here depending on preference, application, and budget... do your research. Swaybars are good. Most people get Suspension Techniques or Neuspeed. Suspension Techniques are cheaper and seem to be easier to find.
Chassis Reinforcement - When you do an engine swap you compromise the structural integrity of your car. Strut bars and tie bars will help. You can get any brand, even cheap as hell ones off ebay and places like procarparts will make it better. You may or may not need a new front crossmember... it depends on what you want to do with the car... once again do your research. Motor mounts you will need with the new engine.
Wheels/Tires - All of the above gives you more chassis rigidity. More chassis rigidity means your suspension will easily overpower your stock rubber. Get some lightweight 15" or 16" rims that allow at least 205 tread. Diminishing returns applies and larger rims will most likely just be heavier and slow you down. Don't go cheap on tires. No matter how much you spend on bolt-ons for upgraded handling and power your car will only be as fast and handle as well as your rubber allows it to. Buy as much grip as you can afford.
Brakes - More weight means more time to stop. Upgrade at least the front brakes to at least 10.3" rotors/4 piston calipers. 11" rotors/4 piston calipers would be better but you need said 15" or 16" rims first and it is more expensive. Upgrading rotors and calipers means you need upgraded master cylinder and possibly brake booster. A '90-91 Civic Sedan EX master cylinder will bolt-on to your current brake booster, a '90-91 Integra master cylinder will be even better but you have to get the brake booster with it.
Exhaust except for header - at least 2", 2.25 seems to be a sweet spot, though a lot of people like 2.5" as well if they are doing more than bolt-ons
Of course you don't have to do all of this before the swap, but you might as well get started. I'd leave performance related stuff for last and focus on handling for now. The handling benefits you can enjoy with your current engine, and it's better to worry about the performance stuff after the swap is done and you have a clearer understanding of what you want to do with your engine (just bolt-ons, internals as well, forced induction of some sort, etc).
Old Jul 10, 2003 | 04:42 PM
RCautoworks's Avatar
Default Re: What parts can I buy now if I plan on getting a B16A later..? (B17ACRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B17ACRX &raquo;</TD></TR><TR><TD CLASS="quote">These are things you're going to want to upgrade:
Suspension - Heavier engine = more weight up front = more understeer. Get new shocks/springs... lots of choices and combos here depending on preference, application, and budget... do your research. Swaybars are good. Most people get Suspension Techniques or Neuspeed. Suspension Techniques are cheaper and seem to be easier to find.</TD></TR></TABLE>
I would not worry about the engine being a lot heavier, its only about 50 pounds if that heavier.
Old Jul 10, 2003 | 04:57 PM
B17ACRX's Avatar
Default Re: What parts can I buy now if I plan on getting a B16A later..? (90blackcrx)
I might be wrong but the figures I've seen (from the resource) are 100lbs heavier for a B16A versus the D16A6. That's like driving around with someone sitting on your hood with the stock suspension and brakes (that's what it felt like before I redid mine anyway, although I have a B17A so I think it's even a bit more heavy).
crxsteve
May 28, 2007 09:01 PM
Soullessone
Jul 14, 2005 08:03 AM
I3ackfire
16
Mar 25, 2004 06:47 AM
v8killr
May 9, 2002 01:47 PM
