Help drop my civic!
where do you live? If you in central PA i can do them for ya..... if not......
1. Put car up on jackstands (level ground for safty)
2. remove the lower control arm bolts that hold the shocks inplace
3. remove the top two bolts that are found under the hood and in the rear trunk...
4. turn the stock shocks and they should slide right on out no problems
5. Compress aftermarket springs onto new shocks and slap them in and put bolts on and tightn up....
Very easy process... I've done it so many times, if i have all the parts there and ready i can do a complete spring/shock change over in about 20-25 minutes tops.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outkast »</TD></TR><TR><TD CLASS="quote"> if i have all the parts there and ready i can do a complete spring/shock change over in about 20-25 minutes tops.</TD></TR></TABLE>
thats pretty damn fast, it takes me 20 minutes just to jack the car onto stands
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91_hatch_si »</TD></TR><TR><TD CLASS="quote">
thats pretty damn fast, it takes me 20 minutes just to jack the car onto stands </TD></TR></TABLE>
lol That is a bit slow. Should take 10. Lift the front then the back. Doing each corner seperatly would take too long.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outkast »</TD></TR><TR><TD CLASS="quote"> where do you live? If you in central PA i can do them for ya..... if not......
Very easy process... I've done it so many times, if i have all the parts there and ready i can do a complete spring/shock change over in about 20-25 minutes tops.</TD></TR></TABLE>
Do it once and youll say to yourself damn this is easy.....unless the bolts are seized
ShinotakuX
24
Sep 3, 2007 04:54 PM
scyked
Dec 20, 2006 10:36 AM
isuhonda83
Sep 22, 2004 05:44 AM
s0liDyNe
Sep 13, 2002 07:58 PM
Carp
Apr 3, 2002 01:13 PM
