any itr owners use stock cams and Apex vafc?
Old Jul 9, 2003 | 08:34 PM
fuck honda-tech's Avatar
Default any itr owners use stock cams and Apex vafc?
I am wondering it properly tuned with stock cams will a Apex vafc add postive effect on stock cams. OR is it not worth getting until cams are upgraded. Any hp estimates and positive affects by getting the vafc? Thanks in advance.
Old Jul 9, 2003 | 09:46 PM
Default Re: any itr owners use stock cams and Apex vafc? (circuitgsR)
anyone?
Old Jul 9, 2003 | 09:48 PM
B2FiNiTY's Avatar
If you are going to get cams eventually then I would wait. You can save money on tuning by doing it all at once. Although, you can still yield gains from a close to stock setup.
Old Jul 9, 2003 | 10:05 PM
Default Re: any itr owners use stock cams and Apex vafc? (B2FiNiTY)
thanks for the help
Old Jul 10, 2003 | 03:50 AM
Willard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by circuitgsR &raquo;</TD></TR><TR><TD CLASS="quote">will a Apex vafc add postive effect on stock cams.</TD></TR></TABLE>
Yes it has a positive effect with stock cams.
Plus, you retain the OBD2 stuff to pass inspection (at least for me).
https://honda-tech.com/zerothread?id=511707
Old Jul 10, 2003 | 04:21 AM
PM-Performance's Avatar
Default Re: any itr owners use stock cams and Apex vafc? (Willard)
my vafc worked out nice for me , i gained like 9-10 whp thurout the band and made some really decent na numbers, off hand it was like 194whp and 131 tq, its been a while, but that was no cams , nor cam gears or anything like that
Old Jul 10, 2003 | 05:00 AM
DC2R714's Avatar
Default Re: any itr owners use stock cams and Apex vafc? (itr206)
Gravity gained like 5-10whp and midrange from tuning the VAFC on boltons. Its a useful item as you keep adding things to your setup you can tune with it. Has worked well for me N/A and Turbo.
Old Jul 10, 2003 | 05:52 AM
NSX Bob's Avatar
New User
Default Re: any itr owners use stock cams and Apex vafc? (DC2R714)
I used it for a while w/ stock cams, but if you are going to upgrade the cams later I would suggest waiting and just getting a hondata.
Old Jul 10, 2003 | 01:45 PM
Default Re: any itr owners use stock cams and Apex vafc? (Type R Bob)
thanks for the help people
Old Jul 10, 2003 | 02:28 PM
Blazeone's Avatar
used on my stock motor with an aem and gained 5whp throughout the power range.
Old Jul 10, 2003 | 02:31 PM
Hooch'n's Avatar
Default Re: any itr owners use stock cams and Apex vafc? (redx)
Yes, it is a good mod.........playing nintendo in ITR=FUN
Old Jul 10, 2003 | 02:36 PM
RiCE On IcE 2's Avatar
Default Re: any itr owners use stock cams and Apex vafc? (Hooch at 8400-RPM)
think AFC would void warranty? Even though it is easy enough to just yank the wires out? I think you'd probably really have to mess up the tuning to blow something with boltons and a AFC?
Old Jul 11, 2003 | 07:15 AM
magic hat #9's Avatar
Default Re: any itr owners use stock cams and Apex vafc? (RiCE On IcE 2)
has anyone ever played with cam sprockets on stock cams? could yield some power in conjunction with a vafc.
Old Jul 11, 2003 | 08:21 AM
B2FiNiTY's Avatar
Yes it will kill your warranty in most cases.
Cam gears might or might not help the car depending on the setup and how you would like your power.
Old Jul 11, 2003 | 08:36 AM
JoshRambo's Avatar
Yeah it is worth it to get it tuned on stock cams.
My aif/fuel was all wacky. Once it was tuned i gained some nice power.
Old Jul 11, 2003 | 09:17 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">Yes it will kill your warranty in most cases. </TD></TR></TABLE>
45,100 miles and knocking 'em off quick
Old Jul 11, 2003 | 09:27 AM
tc's Avatar
tc
It's a good mod to have.
I gained 5-10 in midrange, and 3-5 up top.
Old Jul 11, 2003 | 01:55 PM
Lost Type R's Avatar
a VAFC is not that emissions friendly, wont pass visuals.
Old Jul 11, 2003 | 03:54 PM
cletus's Avatar
Default Re: any itr owners use stock cams and Apex vafc? (Lost Type R)
hide it!!!! dont want would be thieves to see it either
Old Jul 11, 2003 | 04:00 PM
Default Re: any itr owners use stock cams and Apex vafc? (cletus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cletus &raquo;</TD></TR><TR><TD CLASS="quote">hide it!!!! dont want would be thieves to see it either</TD></TR></TABLE>
cant, they will check if anything is tapped into your ECU
Old Jul 11, 2003 | 11:20 PM
it's easy pretty easy to remove the wires though eh.. or coudl run hondatat and swap the ECu wen needed?
Old Jul 11, 2003 | 11:38 PM
thanks for the replies those of you that stayed on topic
Old Jul 12, 2003 | 12:21 AM
jdmspoonitr's Avatar
I made 30-15 whp through out the 4000-6000 range just by lowering the vtec engagement and leaning out the fuel. Great tool for basic tuning, but if you want finer detail use a hondata.
vteccoupe
16
Feb 24, 2008 04:51 AM
wrXtian
Aug 22, 2005 04:08 PM
fiebru1119
May 25, 2002 08:45 AM
Hukd Up
Jun 26, 2001 04:10 AM
