why do turbo kits face the turbo the crappy way???
Old Jul 9, 2003 | 06:13 PM
sporkcrx's Avatar
Default why do turbo kits face the turbo the crappy way???
All of the kits I've seen, some manifolds, and a lot of turbo set ups have the compressor on the passenger side. Why??? You have to route the downpipe under the turbo, right by the oil return line, instead of just going straight down like if the compressor was on the driver side. Charge piping has to also go under the turbo when the compressor is on the passenger side. You have the downpipe, oil return line, and charge piping all snaking under the turbo, when it can all be avoided by mounting the compressor on the driver side. I've always hated this design and always wondered why all of the kits use it this way, there must be a reason.
Old Jul 9, 2003 | 06:16 PM
93LSivic's Avatar
Default Re: why do turbo kits face the turbo the crappy way??? (sporkcrx)
Couple reasons.
People like the a/c.
Most radiators dont have an opening in the middle to allow for compressor/turbine housing placement.
Putting a filter on it would require a good amount of crazy piping to run into the tire well to avoid a/c and power steering.
Guess that pretty much sums that up.
BDaTurboTeg
May 19, 2007 11:06 PM
rsteggy98
Dec 10, 2005 07:55 PM
EG5_Si
Sep 8, 2005 05:03 PM
AaronJ
Dec 3, 2003 07:54 AM
Mr. Vapor
Oct 4, 2001 07:36 AM
