DOHC ZC swap, car won't start
Old Jul 9, 2003 | 03:19 PM
DesiDez's Avatar
Default DOHC ZC swap, car won't start
car wont crank over. here's what we've done so far:
1. dx to zc wiring, ecu throws one code: 10 ( air intake sensor)
2. grounded the thermostat ground, it wasn't grounded before
3. check spark, firing order, and distributor, even battery- seems all good
one problem: fuel is leaking out of the canister by the firewall- any ideas to stop this?
any other problems we might be missing.
Old Jul 9, 2003 | 03:45 PM
DJ_SaNdOz's Avatar
Default Re: DOHC ZC swap, car won't start (FOBsquad)
fix teh fuel leak ASAP- that could prove to be dangerous. Did you make sure that the injector's are firing & getting the correct voltage/ohms? Are you 110% sure on teh dizzy & harness wiring? is the starter trying to work? Is the fuel pump coming on? (I'm assuming that the fuel pump works though b/c of teh leaky line). I dunno, just make sure to quadruple check everything.
Old Jul 9, 2003 | 03:50 PM
Outsane's Avatar
Either tighten down the fuel line hoses more, or get some new copper washers..is the bleeder screw tightened down?
What exactly is happening?
does the motor turn and just not start up.. or is it not even chugging around?
Old Jul 9, 2003 | 05:21 PM
FourthGenHatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOBsquad &raquo;</TD></TR><TR><TD CLASS="quote">car wont crank over. here's what we've done so far:
one problem: fuel is leaking out of the canister by the firewall- any ideas to stop this?</TD></TR></TABLE>
Same thing happened to me. It turned out my plugs were in the wrong spot. There are like 3 clips that are all the same so make sure you are plugging in the right one.
Also make sure all your grounds are hooked up, such as the thermostat ground.
Old Jul 15, 2003 | 10:28 AM
DesiDez's Avatar
Default Re: DOHC ZC swap, car won't start (FourthGenHatch)
new problem. car has been running for the last couple of days but, today when i go to try and start the car, nothing happens. it doesn't even attempt to crank.
battery, i think is still good, b/c the headlights, radio turn on.
i haven't done anything to the car for it not to start since i last drove it.
Old Jul 15, 2003 | 01:31 PM
DJ_SaNdOz's Avatar
check the starter then
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOBsquad &raquo;</TD></TR><TR><TD CLASS="quote">new problem. car has been running for the last couple of days but, today when i go to try and start the car, nothing happens. it doesn't even attempt to crank.
i haven't done anything to the car for it not to start since i last drove it. </TD></TR></TABLE>
Old Jul 16, 2003 | 08:26 AM
Outsane's Avatar
Jump it..
I have had a car not start because of battery issues and still be able to turn the headlights on..
Once you get it started try pulling off the neg. battery lead while the car is running to see if the alternator is working or not..
eazye5591
Dec 19, 2012 05:26 AM
InTheLBC20
12
Oct 2, 2009 08:21 AM
liloldchevyvan
Jan 17, 2008 08:39 AM
SwissChEz82
20
Feb 2, 2005 06:37 PM
96-EJ6 B18C
Apr 15, 2004 05:33 PM
