Just Installed S-AFC II and now i have Check Engine Light........
Old Jul 9, 2003 | 03:13 PM
2000 Integra R #760's Avatar
Default Just Installed S-AFC II and now i have Check Engine Light........
Well i fixed the wiring problem i had and i have another question for you guys. scroll down a few posts to see my new question and explain my reason for getting a S-AFC II instead of V-AFC.
Modified by 2000 Integra R #760 at 12:59 AM 7/13/2003
Old Jul 9, 2003 | 03:16 PM
VTECPWR's Avatar
Default Re: Just Installed S-AFC II and now i have Check Engine Light........ (2000 Integra R #760)
What code are you getting?
Old Jul 9, 2003 | 03:43 PM
98R-1144's Avatar
Default Re: Just Installed S-AFC II and now i have Check Engine Light........ (VTECPWR)
did u reconnect the VTM from the engine to the ecu? i think there are 2 wires that the VAFC uses that the SAFC doesn't use.. (VTM and something else) you need to hook those to back up to it's original connections.
Old Jul 9, 2003 | 03:46 PM
I dont know how to check engine codes.
Old Jul 9, 2003 | 03:47 PM
Default Re: Just Installed S-AFC II and now i have Check Engine Light........ (98R-1144)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98R-1144 &raquo;</TD></TR><TR><TD CLASS="quote">did u reconnect the VTM from the engine to the ecu? i think there are 2 wires that the VAFC uses that the SAFC doesn't use.. (VTM and something else) you need to hook those to back up to it's original connections.</TD></TR></TABLE>
The car was running fine with no check engine light for the whole year i had it. For that whole year there was no V-AFC in the vehicle. Now that i put a s-afc in the car i have check engine light.
Old Jul 9, 2003 | 04:27 PM
I'm getting a code 9. I checked c-speedracing.com and it said its a
CYP sensor (cylinder) defective circuit or unplugged / defective sensor.
Um what do i do now?
Old Jul 9, 2003 | 05:48 PM
Dave-ROR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000 Integra R #760 &raquo;</TD></TR><TR><TD CLASS="quote">I'm getting a code 9. I checked c-speedracing.com and it said its a
Um what do i do now? </TD></TR></TABLE>
check your wiring. sounds like you cut into the wrong wire. Why a S-AFC anyways?
Old Jul 9, 2003 | 09:50 PM
B2FiNiTY's Avatar
Default Re: Just Installed S-AFC II and now i have Check Engine Light........ (FizzleDaKlown)
I believe he wants to tune everything but vtec. It has to do with your wiring for sure.
Old Jul 10, 2003 | 06:07 AM
Dave-ROR's Avatar
Default Re: Just Installed S-AFC II and now i have Check Engine Light........ (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">I believe he wants to tune everything but vtec. It has to do with your wiring for sure. </TD></TR></TABLE>
A VAFC is the same price no? And VTEC Xover adjustment is a good thing.
Old Jul 10, 2003 | 07:20 AM
Johnny Tran's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FizzleDaKlown &raquo;</TD></TR><TR><TD CLASS="quote">
A VAFC is the same price no? And VTEC Xover adjustment is a good thing.</TD></TR></TABLE>
ahh what do you know dave? does your gee--ess-arrRR even have b-tek ?
Old Jul 10, 2003 | 10:40 AM
Can be wired for DC2 thats all Im going to say.
Old Jul 12, 2003 | 11:50 PM
Well its fixed i did splice into the wrong wire . But after long hours of laying in bed trying to go to sleep i figured it out.
BTW: does anyone know how to wire up a spoon vtec controller for eg civic to a dc2? I remember hearing something about a obd1 jumper but im not 100% sure on how to wire it up cause im looking into getting one soon. Thanks
Old Jul 13, 2003 | 12:16 AM
cheezthis's Avatar
What's so special about the spoon vtec controller? I'm not trying to be rude, I'm actually curious. Where does it differ from a vafc in terms of vtec engagement/disengagement?
As for the wires...not sure, I'm obd-1.
Old Jul 13, 2003 | 02:07 AM
Default Re: Just Installed S-AFC II and now i have Check Engine Light........ (cheezthis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cheezthis &raquo;</TD></TR><TR><TD CLASS="quote">What's so special about the spoon vtec controller? I'm not trying to be rude, I'm actually curious. Where does it differ from a vafc in terms of vtec engagement/disengagement?
As for the wires...not sure, I'm obd-1.</TD></TR></TABLE>
It really does not differ. The one thing is that you can change vtec engagement on the fly (in the middle of a race, circuit or road course) which can be important sometimes. Also it is spoon and Im a spoon *****. Also i heard that the S-AFCII has more settings for air and fuel then the V-AFC. So i can have the best of both worlds. Vtec control and the better then V-AFC, S-AFCII settings.
dzzrunnin411
Jan 20, 2007 10:35 AM
sagron69
11
Mar 19, 2004 06:51 PM
brian2903
Dec 11, 2003 06:24 PM
Tuan
May 13, 2002 03:36 PM
ITR 2K
Jan 16, 2002 10:48 PM
