Valve springs A6 or Z6 what the difference
Old Jul 9, 2003 | 10:19 AM
JDMCRX's Avatar
Default Valve springs A6 or Z6 what the difference
I can get a set of valve springs for a A6 there JG im just wondering whats the difference between the two. I know the retianers are the same but the springs are different part numbers but whats different?
Old Jul 9, 2003 | 10:24 AM
TurbodCX's Avatar
Default Re: Valve springs A6 or Z6 what the difference (JDMCRX)
I know the compressed height is different, because the Z6 has Vtec, and the A6 doesnt.
If you are thinking of useing the A6 springs in the Z6 head, i wouldnt recommend this at all.I could almost garuntee you that you will see some spring coil bind and then.........................................BOOM! !!
HTH
Brian
Old Jul 9, 2003 | 10:26 AM
JDMCRX's Avatar
Default Re: Valve springs A6 or Z6 what the difference (TurbodCX)
ah ok **** it then but i can use the retianers tho ??? there alum?
Old Jul 9, 2003 | 10:27 AM
JDMCRX's Avatar
U would not know the spring height eh???
Old Jul 9, 2003 | 10:57 AM
TurbodCX's Avatar
I am not sure on the exact spring height.
I am sure you can use the retainers, but you may be better off to match the retainers up with the same brand name of spring.
Brian
civic00sir.
Mar 19, 2010 09:59 AM
Hella_Fresh
Mar 13, 2007 01:37 AM
GersWorkz
Mar 27, 2006 07:30 PM
Pfieff
13
Apr 7, 2004 05:02 PM
BenenEK
Jan 30, 2002 07:53 AM
