pg7 ECU differences
whats the difference in the following ECU's
pg7a01
pg7a02
pg7a03
pg7a04
all are 89 teg 5spd ecu's
whats is the difference in them?? looking to put into ZC powered 91 Si .
thanks
pg7a01
pg7a02
pg7a03
pg7a04
thanks
all the ecu s in all trim models of the 88-89 are supposely the "same"
thats maybe a code to designate them from trim mdoel to trim model..
as long as u got a PG7 from 88-89 it will work....
does anyone know whether or not the PM7 ECU (86-87 teg) can be chipped? I see people selling chips for them, however, I hear that they are very very hard to chip and require a different chip to make functionable.
From: the asshole of america..., upstate new york, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jasonb »</TD></TR><TR><TD CLASS="quote">does anyone know whether or not the PM7 ECU (86-87 teg) can be chipped? I see people selling chips for them, however, I hear that they are very very hard to chip and require a different chip to make functionable.</TD></TR></TABLE>
PM7 is JDM ZC ecu...86-87 teg is still PG7 but is different than 88-89. i dont think you can chip them...they dont run an internal coil setup anyways.
there might be chips for the PG7 (86-87)
BUT
those ECU's are vacum advanced.... they will only work on advanced engines.. they have no use for our MPFI 88+
they wont turn ur engine on....
BUT
Are PG7 ECU's only from 86-87? The one I have on it is stamped with a date from 87. But I plugged the ECU in and the car started right up. If it were infact an ECU from 86-87, it should start right up, correct? I have yet to drive the car with the ECU in. THe car is still on the trailor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jasonb »</TD></TR><TR><TD CLASS="quote">1.) Are PG7 ECU's only from 86-87?
2.) The one I have on it is stamped with a date from 87. But I plugged the ECU in and the car started right up.
3.) If it were infact an ECU from 86-87, it should start right up, correct?</TD></TR></TABLE>
1.) no - 88-89 also
2.) 87 is the date manufactured...its probably from an 88 if it runs.
3.) from what ive heard it shouldnt even run.
1.) no - 88-89 also
so geting back to the question i asked on this thread.......
does any one know the what the difference in the following ECU's
pg7a01
pg7a02
pg7a03
pg7a04
no offense jason, but can u start ur own thread on this on ??
pg7a01
pg7a02
pg7a03
pg7a04
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bc_psychocivic »</TD></TR><TR><TD CLASS="quote">whats the difference in the following ECU's
pg7a01
pg7a02
pg7a03
pg7a04
thanks
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC »</TD></TR><TR><TD CLASS="quote"> all the ecu s in all trim models of the 88-89 are supposely the "same"
i already answered you! they are all 5 spd
pg7a01
pg7a02
pg7a03
pg7a04
thanks
