Fuel injector size - NA build up
Alright I'm trying to figure out what the stock injector sizes are. Anyone know where I could find a list of all the injector sizes for honda/acura/mitsu ?
I'm really interested in the b18c ones.. I'm probably gona go NA.. so with m24 cams, ti head a P&P job, and a 12:1 cr. I have no clue what size of injectors I would need so that I don't blow my ****, and also if the stock b18c ones would do the trick. Also if I upgrade the injectors, I'm sure a better flowing fuel pump and fuel rail would be better, then what should I get?
i was thinking maybe the walbro 255 ( since they are somewhat cheap) and aem fuel rail would do the trick, but is there a true need for it? What kind of tuning would be needed to make sure the car can run ona daily basis without any problems?
Thanks to everyone for comments/suggestions/flames for not going fi
etc...
etc...
For which engine ? If this is for a D16, don't bother with the B18, they are the same.
http://www.allmotorhonda.com/t...r.htm
JustAnotherHonda
Mar 9, 2003 09:15 PM
