clutch...HELP
Old Jul 9, 2003 | 05:49 AM
buda18's Avatar
Default clutch...HELP
ok so im not an expert but i didnt think clutches just go out outa nowhere...and thats wut happend to me the other night.....it wasnt engaging like i always has....finally took it home...now when i press the clutch down to try to get it outa my garage...it just stays at the bottom like theres nothing there....i checked my brake fluid....i didnt have ne..oops...but i poured some in now and still the same prob...someone said it could be the master cylinder and if it is, it should be leaking in ur car and u can smell the fluid...but i dont smell nething, but neways if u guys have ne ideas please help me, i wanna drive my baby
thanks guys
Old Jul 9, 2003 | 06:11 AM
jaxle's Avatar
My clutch master cylinder leaks and i cant smell the fluid at all, but you can tell by looking by your clutch pedal and if its leaking your carpet would be stained with fluid. It has pretty much destroyed my floor mat :/ Anyways check all your clutch lines and you need to bleed the clutch fluid too b/c now there is air in the line, that is why your clutch still does not work. Get a Haynes manual if u dont know how.
Old Jul 9, 2003 | 06:18 AM
SpyderZEX's Avatar
Default Re: clutch...HELP (buda18)
Is it your clutch that isn't working or your brakes that aren't working? It sounds like you need to fill the clutch slave cylinder.
Old Jul 9, 2003 | 06:20 AM
buda18's Avatar
Default Re: clutch...HELP (SpyderZEX)
yeah its the clutch ....lol wheres the clutch slave cylinder
Old Jul 9, 2003 | 06:26 AM
Moe's Avatar
Moe
its right on the front of the tranny, just infront of the radiator, its black and should have a bleed hole on it. Your system needs to be bled and that should help your problem, if not........
Old Jul 9, 2003 | 08:43 AM
jaxle's Avatar
Default Re: clutch...HELP (Moe)
Well unless he was taking out clutch lines or sumthin, the air had to get in there somehow. Probably a big leak somewhere if it drained all in one night.
Old Jul 9, 2003 | 09:09 AM
SpyderZEX's Avatar
Default Re: clutch...HELP (jaxle)
A similar thing happened to me about a year, or so, ago. I bled the system and added more fluid and never had a problem since.... weird, but true.... I thought that I had a leak too, but wanted to see if it would lose pressure again and it never did.
SICCF22
Jul 30, 2011 01:40 AM
AllMotorRP
Honda S2000
Mar 23, 2009 07:41 PM
Gomdohree
Apr 24, 2008 06:20 AM
eg6sittingon57cs
Aug 8, 2007 10:44 AM
Tealeg88
10
Feb 17, 2006 08:19 PM
