oil changing question...
Old Jul 9, 2003 | 04:55 AM
RAS Motorsports's Avatar
Default oil changing question...
i got 4 quarts of honda 5w-30 motor oil for free...i think i need 4.5 quarts...not exactly sure...but i have about half a quart of another brand thatz 5w-30 also. can just mix it in together? long as itz not synthetic ryte?
Old Jul 9, 2003 | 04:57 AM
beefpigs's Avatar
Default Re: oil changing question... (95GeeZR)
I don't see the problem. I have never done that before but I can't see what would go terribly wrong.
Anyone else know?
Old Jul 9, 2003 | 04:59 AM
lustedp's Avatar
yea it shouldnt be a problem to top it off with another oil
Old Jul 9, 2003 | 05:07 AM
Default Re: (lustedp)
i also alwayz wondered wha would happen if i added in 10w-30 to 5w-30? anybody kno?
Old Jul 9, 2003 | 06:48 AM
romeo619romeo's Avatar
Default Re: (95GeeZR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GeeZR &raquo;</TD></TR><TR><TD CLASS="quote">i also alwayz wondered wha would happen if i added in 10w-30 to 5w-30? anybody kno?</TD></TR></TABLE>
one will sit lower then the other.. like cooking oil and water
Old Jul 9, 2003 | 06:59 AM
IntEGNYC's Avatar
Default Re: (romeo619romeo)
it shouldnt do any harm though its recommended not to mix brands.
Different viscosity within a brand should be okay.
Old Jul 9, 2003 | 07:52 AM
JL 74's Avatar
25 Year Member
Go for it.
Old Jul 9, 2003 | 08:00 AM
TegLove's Avatar
Default Re: (IntEGNYC)
mayeb im the dumbass here but i thought it was liek 3 1/2 quarts.... I have this discussion every 5000 miles and i still never remember the outcome
Old Jul 9, 2003 | 08:09 AM
mech's Avatar
Default Re: (TegLove)
Honda puts in like 3. 7 in the dual cam motors and i think 3.2 quarts in the single cam. I'm going by what a friend told me who works their.
Old Jul 9, 2003 | 08:12 AM
THE94GSR's Avatar
Default Re: (mech)
i thought it was 4 quarts that what i use on my 94 gsr
Old Jul 9, 2003 | 08:16 AM
P1mpSlap's Avatar
Default Re: (mech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mech &raquo;</TD></TR><TR><TD CLASS="quote">Honda puts in like 3. 7 in the dual cam motors and i think 3.2 quarts in the single cam. I'm going by what a friend told me who works their.</TD></TR></TABLE>
4.5 brings it up to the 2nd dot on the dipstick. 4 quarts brings it to the 1st dot on the dipstick. Running anything less in the motor risk damaging your engine and higher temps.
Old Jul 9, 2003 | 08:56 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (P1mpSlap)
i've never put in anything more than 4 quarts exactly, and it always comes up to the top hole on the dipstick... that's after draining it for a long time too.
Old Jul 9, 2003 | 08:57 AM
JL 74's Avatar
25 Year Member
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">i've never put in anything more than 4 quarts exactly, and it always comes up to the top hole on the dipstick... that's after draining it for a long time too.</TD></TR></TABLE>
I notice the same thing. After four quarts, it is just right at the top of the dipstick.
Old Jul 9, 2003 | 09:11 AM
JL 74's Avatar
25 Year Member
Default Re: (evan2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evan2 &raquo;</TD></TR><TR><TD CLASS="quote">i know the b18c1 holds 4.5
i think the b18b holds 4.. </TD></TR></TABLE>
b18c1 is 4.2 per owners manual
Old Jul 9, 2003 | 09:49 AM
Aaron M's Avatar
last oil change mine took a little over 4.5 quarts
are you guys blowing the old oil out via the valve cover breather hose? thast about .5 quarts right there
Old Jul 9, 2003 | 09:55 AM
epy's Avatar
epy
Default Re: (SilverB18C1)
I put in anywhere from 4.2-4.5 It is important to bring your oil level up to the 2nd dot if you have a b18c(1,5) motor or vtec gets angry
There isn't a problem mixing those oils. I've met a few people who mix on purpose. I don't quite understand why there were but i know it's not harmfull. I rather use all of the same visc.
Old Jul 9, 2003 | 10:19 AM
integraL's Avatar
b18b = 4.0 qt
b18c = 4.2 qt
i heard that 4.0 is enough because you dont drain all of the oil anyway.
Old Jul 9, 2003 | 10:21 AM
IntEGNYC's Avatar
Default Re: (integraL)
i use 4 quarts on my b18b
Old Jul 9, 2003 | 10:44 AM
kha's Avatar
kha
i use 10w-30 ??
Old Jul 9, 2003 | 12:01 PM
IntEGNYC's Avatar
Default Re: oil changing question... (kha)
10W30 should be fine.
Old Jul 23, 2003 | 01:14 AM
epy's Avatar
epy
depends on where you live, the climate.
I live in washington and the weather is pretty consistant in temp. I use 5w30 Syn (mobile 1 bai's)
I just changed my oil tonight and had to put in a little more than the 4.2 (says the manual)
My engine likes to burn about 1 qt every 1500 ;(
Old Jul 23, 2003 | 01:57 AM
Stewie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by romeo619romeo &raquo;</TD></TR><TR><TD CLASS="quote">
one will sit lower then the other.. like cooking oil and water</TD></TR></TABLE>
I agree! Different viscosities don't mix. It's recommended not to do this.
Old Jul 23, 2003 | 08:16 AM
maxxdout's Avatar
Default Re: (Mac8008)
there is no damage caused in doing this. If i dont have extra 5-30 laying around in goes 10. WHy, cause i dont care and i dont feel like tracking down 5-30 with its just going to leak out of the pan gasket.
would i mix 90W gear oil with motor oil.....probably not, but come on, 5W and 10W.........
Old Jul 23, 2003 | 11:48 AM
Stewie's Avatar
Default Re: (maxxdout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxxdout &raquo;</TD></TR><TR><TD CLASS="quote">there is no damage caused in doing this. If i dont have extra 5-30 laying around in goes 10. WHy, cause i dont care and i dont feel like tracking down 5-30 with its just going to leak out of the pan gasket.
would i mix 90W gear oil with motor oil.....probably not, but come on, 5W and 10W.........</TD></TR></TABLE>
I agree that it doesn't cause damage. Obviously many people have done including you and they don't notice a difference. I have even done it myself.
Similarly, using non sythetic oil doesn't cause damage, but many people chose to use synthetic. I think you would agree that using the same viscosity is probably best. Who knows.... It doesn't really bother me anyway
C_H_A_D
47
Apr 20, 2009 09:04 PM
C_H_A_D
12
Jul 10, 2008 04:49 PM
r6toeg6
12
Dec 19, 2005 05:09 PM
illagee
Nov 6, 2005 05:21 PM
Shaun
32
May 26, 2004 03:46 PM
