at what milage do you adjust valves?
my 98 accord 5 speed manual got 126 k on it. I heard something bout adjusting valves to improve powerr and gass milage.when are you suppose to adjust valves? is there a cetain milage??
Or if you are my local dealer, you adjust the valves every 30,000 miles (no, I don't actually go there, but a friend's wife just paid ~ $300 or $400 for her 30,000 mile maintenance on a '99 Accord, it included adjusting the valves even though her car was running perfectly).
oO0oO, so thats why my civic engine was so noisey. i just bought a 98 accord with 126k. ill have them adjusted when i change my timing belt. but the engine is quite anyway still.
5 spd and runs like a champ
If you have some minor mechanical inclination you can do it yourself. I did my Accord's a few months back around 36k miles and found that most of the clearances were too tight and they weren't very uniform (this is on a car that isn't supposed to need valve clearance adjustment until 105k miles). If your performance and fuel economy are fine and they aren't noisy, they really don't need to be adjusted. They've got to be pretty far out of spec to cause a noticable problem.
I believe the Helms manual states to check the valve clearence every 15,000 miles I cehcked mine after about 10,000 miles and my exhaust side valves were loose so check them out its not that hard to do with the help of a friend.
Accordhybrid
Accordhybrid
KimvdLinde
May 27, 2013 05:20 PM
Wrath of VTEC
Sep 4, 2003 06:50 AM
