Just bought 4th gen hatch and the shifter is very stiff
Old Jul 8, 2003 | 09:02 PM
adnoh90Civic16's Avatar
Default Just bought 4th gen hatch and the shifter is very stiff
Just bought 4th gen hatch and the shifter is very stiff what can I do to make it smoother and how???
Old Jul 8, 2003 | 09:09 PM
streetlegal gocart's Avatar
the shift rod bolt, the one that's transverse right below the shifter, might be too tight, poss. need new bushings. If its hard to get into gear it could need a clutch cable adjustment. Otherwise, maybe check tranny fluid.
Old Jul 9, 2003 | 05:51 AM
whippincivic's Avatar
Default Re: (Doctor Zagato)
It will be the bolt underneath I had the exact same problem with mine when i got it. because it had been sitting lying around for a while it got seezed and tight but it only takes a couple of mins to fix like doctor zagato says.
Old Jul 9, 2003 | 06:14 AM
USDM 4G VTEC's Avatar
Default Re: Just bought 4th gen hatch and the shifter is very stiff (adnoh90Civic16)
some times if clutch needs adjustment can make the shifter a lil hard to put on gears.,.
if thats not the case and even hard on neutral, i would lubricate and grease the whole shift linkage....
Old Jul 13, 2003 | 11:21 AM
thank you
contractkiller
Feb 18, 2008 06:27 PM
raylude
Jan 7, 2006 02:42 PM
EG_Civic_Si
Dec 22, 2005 06:50 AM
kriptik
Oct 4, 2004 03:50 PM
SOHCArchangel
Dec 2, 2002 09:33 AM
