turboing my 92 integra
werd talk to the FI peeps to get more people who know what they are taklking about lol. also check out g2ic they have some tite g2's there and some are runin nice turbo LS setups on g2 tegs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra2bfrcd »</TD></TR><TR><TD CLASS="quote">whnt some info on internals i should go with befor i do the torbo.(rods,pistons,bore,valves,valvesprings,retai ners,cams)? thanks alot </TD></TR></TABLE>
if its an LS and you just wanna do like 6-9 psi, your rods, pistons, bore, valves, springs, retainers, and cams are fine stock.
if you wanna do more than 9 psi, then you'll wanna get new rods, pistons, and sleeves. stock cams are great for forced induction due to the minimum overlap between the intake and exhaust. as for valve train, you should be good at stock. ask in FI for more turbo related questions.
if u gonna turbo mine as well do it roght with a build. crower makes good rods and cams and je pistons are really good.
i run all those on 15 psi on a 90 integra and i have no problem. and also check out port flow design the build heads there. go with the ferra valve train
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blueintegra90 »</TD></TR><TR><TD CLASS="quote">also they will only bore a motor to 85mm for turbo app.</TD></TR></TABLE>
On what block? B18B on has a 81mm bore no way in **** are they going to bore that thing to 85mm. You wouldn't have any damn sleeves left.
Get a Dart block if you are going to do some crazy **** like that.
