weird brake prob
well sometimes when i am driving and i press the brake , the pedal will be higher and sometimes lower when i press it,,,like an example,,lets say i am comin up to a stop light and i stop,,the pedal seems high,,,then i go and stop at another stop light it seems lower,,but both times the car stops fine,,what do you guys think it could be,,i checked the brake level it seems fine?
Could be air in your lines and the different pedal heights could be how much pressure is in them. Also could be your Brake booster going bad. I would bleed your brakes and see if that helps if you dont have a leak anywhere.
I had a problem like that. But every now and then, the pedal would just fall to the floor. I replaced my brake booster (master cylinder) and of course bled them, and the are good as new.
stevescivic
13
Apr 14, 2014 02:23 PM
