special edition gsr
Old Jul 8, 2003 | 01:18 PM
efcivicsi's Avatar
Default special edition gsr
this kid i know has either 98 0r 99 integra special edition gsr, it has a b18c1, but has an ls cluster nad ls wheels, all came like that from the factory, everything original, i don't think the vtec works my ls beat it, i've drivin stock Gsrs before none were this slow, redline on the cluster says 6900rpm, really wierd, can anyone tell me if the vtec didn't comehookedup or something, i'm really curious.
Old Jul 8, 2003 | 01:22 PM
acuraholic's Avatar
Default Re: special edition gsr (efcivicsi)
Huh? Doesn't sound like a gsr to me. At all.
Old Jul 8, 2003 | 01:36 PM
Rory Breaker's Avatar
Youve seen the motor?
Does it say "Special Edition" on the badge on the back?
Special editions are nothing more than GS' which are nothing more than LS' with leather, cd player, spoiler, "gsr" wheels, etc.
Old Jul 8, 2003 | 01:40 PM
dohc-nyne's Avatar
is he only reving to 7000?? lol
Old Jul 8, 2003 | 01:59 PM
lustedp's Avatar
Default Re: (dohc-nyne)
you sure he's the original owner?
Old Jul 8, 2003 | 02:10 PM
timmy8151's Avatar
Default Re: (lustedp)
As others have said, the Special Edition is basically a GSR w/o the engine. Have you popped the hood to see if he actually has a B18C1?
Old Jul 8, 2003 | 02:13 PM
acuraholic's Avatar
Default Re: (timmy8151)
I thought of the Special Edition, but the ls wheels still throw me.
Old Jul 8, 2003 | 02:20 PM
SonicBlueTeg's Avatar
Default Re: (acuraholic)
u'll wanna check to see if the vin #'s match up... special editions and gsr's are supposed to have identical everything(leather, moonroof, painted sidemoldings, etc.) exception of the different engines.. special edition's do not come with b18c1's in them... remember that the 94-95wheels are 5 spoke... 96-97 gsr wheels are also the ls mesh... and the 98-01 wheels are swirlies...
Old Jul 8, 2003 | 02:45 PM
scrap1ngsr's Avatar
Default Re: (SonicBlueTeg)
[QUOTE=SonicBlueTeg]96-97 gsr wheels are also the ls mesh... QUOTE]
96 gsr and special edition had the same rims but they werent the ls mesh..gsr first came out with the mesh in 97..
Old Jul 8, 2003 | 03:08 PM
NeoGSR's Avatar
Default Re: (CivicSiR94)
1997 GSR=mesh rims
'00-'01 LS=mesh rims (i think that's right )
anyway, just pop the hood and look at the block....it's right in front next to where the tranny bolts up....that won't lie
Old Jul 8, 2003 | 03:10 PM
dohc-nyne's Avatar
99 ls mesh rims too
Old Jul 8, 2003 | 03:34 PM
Vtecfool's Avatar
yea, my '98 gsr came with ls webs, with no Vtec badge on the back. ( i wish i had blades or swirles). But then again... i'm sleeper now..
Old Jul 8, 2003 | 10:08 PM
efcivicsi's Avatar
Default Re: (NeoGSR)
i cheacked the block it said b18c1, and the valve cover says dohc vtec, and so does the rear badge, the engine is definately a b18c1, but it feels so slow and the rpm guage says redline right under 7000
Old Jul 8, 2003 | 10:20 PM
xx dc2teg xx's Avatar
probably wrong ecu
Old Jul 8, 2003 | 10:43 PM
integraL's Avatar
how do we know if the ECU is gsr?
Old Jul 8, 2003 | 11:35 PM
sPaRk'iT's Avatar
WTF!!! im lost!
Old Jul 8, 2003 | 11:50 PM
SPOON DC2's Avatar
Default Re: (xx dc2teg xx)
Old Jul 9, 2003 | 12:46 AM
Loveless's Avatar
Default Re: (integraL)
rmove the driver side kick panel and it shoudl have a list of number, the middle section will say something like p72 or something (i think)
btw even my b18b1 can rev to 7000k before the fuel cut off
Old Jul 9, 2003 | 12:51 AM
boostdd's Avatar
Well this is some weird ****, are u sure nothing has been changed, i think he's lying to you,
Old Jul 9, 2003 | 01:20 AM
xteg95's Avatar
Default Re: (boostdd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostdd &raquo;</TD></TR><TR><TD CLASS="quote">Well this is some weird ****, are u sure nothing has been changed, i think he's lying to you,</TD></TR></TABLE>
he said he checked the block and it said b18c1...my guess is that hes running the ls ecu. also like osmeone else mentioned, check the vin from the block and the chassis, they probably will not match up.
Old Jul 9, 2003 | 04:59 AM
dip-set's Avatar
Default Re: (xteg01)
sounds like a se (special edition) with a swap and rear badge swap...why would u put a se,ls cluster and ecu into a gsr
Old Jul 9, 2003 | 05:22 AM
tub_sephiroth's Avatar
Default Re: (teg-your-it)
NO such thing as special edition gsr.
Old Jul 9, 2003 | 06:05 AM
xteg95's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg-your-it &raquo;</TD></TR><TR><TD CLASS="quote">sounds like a se (special edition) with a swap and rear badge swap...why would u put a se,ls cluster and ecu into a gsr </TD></TR></TABLE>
maybe they never replaced the cluster/ecu w/the engine swap.
Old Jul 9, 2003 | 06:08 AM
dip-set's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xteg01 &raquo;</TD></TR><TR><TD CLASS="quote">
maybe they never replaced the cluster/ecu w/the engine swap.</TD></TR></TABLE>
isnt that what i just said in other words...its an ls (se) with a b18c swap in it...and they havent changed the ecu to the gsr ecu as well as the cluster...
Old Jul 9, 2003 | 06:10 AM
xteg95's Avatar
no...it sounded like you said they put an ls cluster and ecu into a gsr. read what you wrote
