205/45/16
Old Jul 8, 2003 | 12:12 PM
IntegraBoy04's Avatar
Default 205/45/16
Is this a good tire size?
Old Jul 8, 2003 | 12:34 PM
Default Re: 205/45/16 (IntegraBoy04)
Anybody?
Old Jul 8, 2003 | 12:42 PM
acuraholic's Avatar
That would be the preferred size for a 16 inch wheel. So, yes.
Old Jul 8, 2003 | 12:44 PM
Default Re: 205/45/16 (acuraholic)
Thanks.
PoW3l2BaN's Avatar
that size is the closest you will get to matching the stock 195-55-15 on the gsr's and Si's. They aer expensive though. Cheaper and closest match to no vtec integras is 205-40-16. -=o)
Old Jul 8, 2003 | 12:48 PM
Default Re: 205/45/16 (PoW3l2BaN)
What do you mean matching the stock? And is there a difference between tires on VTEC and non VTEC cars?
Old Jul 8, 2003 | 12:57 PM
acuraholic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PoW3l2BaN &raquo;</TD></TR><TR><TD CLASS="quote">that size is the closest you will get to matching the stock 195-55-15 on the gsr's and Si's. They aer expensive though. Cheaper and closest match to no vtec integras is 205-40-16. -=o)</TD></TR></TABLE>
205/40/16 is going to be too short regardless of whether the car is VTEC or not. Your car came stock with a 195/55/15. 205/45/16 would be a little wider with a similar overall diameter.
Old Jul 8, 2003 | 03:53 PM
Aaron M's Avatar
205/45/16
i just ordered a set of es100's today in that size
Old Jul 8, 2003 | 06:38 PM
spoonfed95's Avatar
Go with the 205/45/r16 to be the closest to stock. There is a program on team-integra.net to compare tire sizes. works real good.
Old Jul 9, 2003 | 12:20 AM
polyphony_digital's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraBoy04 &raquo;</TD></TR><TR><TD CLASS="quote">What do you mean matching the stock?</TD></TR></TABLE>
Matching the stock diameter of the tire. This is done for gearing, and the accuracy of the speedo...
195/55/15 tire = 23.44" tall
replace with...
205/45/16 tire = 23.26" tall
advantages: closer to stock diameter, wider selection
or
205/40/16 tire = 22.46" tall
advantages: cheaper, lighter, shorter diamter for less rotating mass, shorter sidewall (which is stiffer for cornering, looks better or worse (opinion) but makes it easier to **** up your rims)...
therefore, the 205/45/16 would be best if matching the stock diameter was your goal, but as you can see, there is more to it than that...
Eihctab
Honda Civic (2001 - 2005)
Mar 26, 2010 06:17 AM
Agent Zero
Honda S2000
27
Mar 20, 2007 03:32 AM
93civicEX
Mar 31, 2006 08:16 AM
DIYaccord
Feb 6, 2005 10:19 AM
2000gsrsedan
Mar 28, 2003 05:18 AM
