Vibration Problems when driving, help!!
Old Jul 8, 2003 | 12:02 PM
ransack's Avatar
Default UPDATE!! HELP!! Vibration Problems
Ok, I was driving my car up to sac and at some points my car would shake, more specfically my right front tire, it would vibrate as if it were not balanced. I took it in to get balanced and my friend that works at Les Shwab said all the tires were fine. They rotated them also. I check all the bolts, everything seemed fine, and I check the tires before it was rotated and it was solid. Any ideas what would cause the virbrations? Anything in the tranny?
thanks
//Jesse
Modified by ransack at 12:25 AM 7/10/2003
Old Jul 8, 2003 | 12:04 PM
ransack's Avatar
Default Re: (SickCiv98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SickCiv98 &raquo;</TD></TR><TR><TD CLASS="quote">check your ball joint? how about shock/ spring? </TD></TR></TABLE>
ball joint was just replaced with honda OEM. THe boot is cracked already though, I didnt like that part.
Old Jul 8, 2003 | 12:57 PM
ransack's Avatar
Default Re: (ransack)
bump
Old Jul 8, 2003 | 01:11 PM
asubennett's Avatar
wheel bearing sounds liek to me
Old Jul 8, 2003 | 05:55 PM
ransack's Avatar
Default Re: (asubennett)
If its the wheel bearing, how do I replace it or what can I do?
Would buying a GSR Disc brake swap replace the bearing?
bdicustoms's Avatar
i had a similer prob, the faster i went the harder it shook, so i checked everything tightened everything up and it still did it so i got new axles and that did the trick
Old Jul 8, 2003 | 06:02 PM
ransack's Avatar
Default Re: (bdicustoms)
I just put a axle.
*sigh* maybe I will have to do it again...
Old Jul 8, 2003 | 06:07 PM
bdicustoms's Avatar
mine seemed to shake on the right side too but i thought id just buy 2 to be on the safe side and its been fine
Old Jul 8, 2003 | 06:24 PM
boostedcivicsir's Avatar
Mr. Badwrench
does it vibrate under acceleration only? does it go away when you let off of it?
if they are the case it is likely an inner joint. here is another scenario.
is it a vibration? or a grinding noise, if grinding, which side? does it go away on left turns? l/s bearing. if it goes away on right turns it is a r/s bearing. the bearing noise usually gets worse, on the opposite side of a turn. I/E on a right turn/ centrifugal force loads loads the left tire. given the info you stated, it seems like it may be an inner joint. yes reman axles have been bad. this is not uncommon for a reman axle. hope that helps.
Old Jul 9, 2003 | 12:55 AM
ransack's Avatar
Default Re: (boostedcivicsir)
it occured when crusing, under acceleration it would continue and under deceleration it would go away. So it could be the inner joint? Where is the inner joint? I just replace the lower ball joint.
I guess later, I will have to get some new axles. try that. I got it for 35, so it wont kill me to bad.
Old Jul 9, 2003 | 03:01 AM
Mr. Badwrench
by inner joint, i mean the inner cv joint. it is the inner half of the axle. itis hard to tell what side sorry.
Old Jul 9, 2003 | 09:37 AM
ransack's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">by inner joint, i mean the inner cv joint. it is the inner half of the axle. itis hard to tell what side sorry.</TD></TR></TABLE>
ahhh thank you
ill guess I will replace that.
someone also said it could be the wheel bearing? is that it maybe?
Old Jul 9, 2003 | 12:09 PM
ransack's Avatar
Default Re: Vibration Problems when driving, help!! (ransack)
bump
Old Jul 9, 2003 | 12:27 PM
Mr. Badwrench
it is possible, but usually on decelleration, no gas pedal, if it isnt there it is usually the inner joint.
Old Jul 9, 2003 | 11:22 PM
ransack's Avatar
Default Re: Vibration Problems when driving, help!! (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">it is possible, but usually on decelleration, no gas pedal, if it isnt there it is usually the inner joint.</TD></TR></TABLE>
allright, I guess I will be replacing my 2 week old axle.
I drove some more tonight (1 hour drive) and at the end of my trip, the vibrations really stated to kick in. It vibrated and it became where I couldnt tell if it was the right side or not. It would happen under acceleration and deceleration. between 40 up to 80 mph. I had a small incident with a ball joint:
https://honda-tech.com/zerothread?id=528043
I had to replace the balljoint and a refurbished axle. So from the way the car acts and the tendencey to vibrate the left side to kinda (its hard to explain) I think it could be the axle.
Old Jul 9, 2003 | 11:25 PM
GTlvr82's Avatar
I have the same exact problem....I get the vibrations at 40-80mph and I get some kind of clunking sound when I turn like something is loose but I tightened everything to spec's and it still has a tendency to do it.
Old Jul 9, 2003 | 11:29 PM
ransack's Avatar
Default Re: Vibration Problems when driving, help!! (GTlvr82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GTlvr82 &raquo;</TD></TR><TR><TD CLASS="quote">I have the same exact problem....I get the vibrations at 40-80mph and I get some kind of clunking sound when I turn like something is loose but I tightened everything to spec's and it still has a tendency to do it. </TD></TR></TABLE>
I'm thinkin you do need to replace your axle. I'm hoping i'm having the same problem
Old Jul 10, 2003 | 12:08 AM
GTlvr82's Avatar
I shOre hope it is just the axle....that is just a little work and sweat. I already replaced one. The other one is showing signs of wear. BUT the damn clunking is coming from the brand new side....makes me wonder. The boots on that sucker still have that new rubber look!
EDIT: If it IS the ball joint how do I go about replacing it (upper and lower)?
Old Jul 10, 2003 | 10:10 AM
ransack's Avatar
allright I replaced the axle and it still vibrates.
It feels like the right wheel is shaking, and it does that under acceleration.
GRRR
what else could it be guys?!!?!??!?!
93egSLEEPER
Jan 4, 2008 03:45 PM
EnjoyTheRideDC2
Aug 31, 2006 11:22 AM
g-ride-si
Jan 12, 2006 02:16 PM
Kyles ej1
Oct 15, 2004 02:23 PM
Kmx
Feb 25, 2004 05:06 PM
