Metallic noise when AC is on...
Old Jul 8, 2003 | 11:55 AM
b18c4door's Avatar
Default Metallic noise when AC is on...
I have my 2K GSR 4 door for about 3-4 days now and I hear a metallic noise when the AC is on. It comes and goes. I am bone stock.
It could be air blowing thru the vents, but seems more metallic and when I turn the fan off, it stops.
Could it be the AC compressor or something similar like the fan? Please advise...
Thanks!
Old Jul 8, 2003 | 11:57 AM
migs's Avatar
Default Re: Metallic noise when AC is on... (b18c4door)
Sounds like it could be a pulley bearing. Seventh Generation Civics had a TSB on this.
Old Jul 8, 2003 | 11:43 PM
X2BOARD's Avatar
Either the compressor clutch is going bad...
or
Your compressor belt is going bad OR loose.
When the belt is loose, it sounds like a metallic scream... but usually stops relatively quickly.
Old Jul 9, 2003 | 05:09 AM
b18c4door's Avatar
Default Re: Metallic noise when AC is on... (X2BOARD)
It has to be the compressor clutch then. Its not the loose belt squealing, thats for sure.
Also, I heard the blower fan has a clutch or some weights and if they are unbalanced it can make some noice, is this true?
plotomatic
Sep 24, 2016 11:10 AM
wickedmaniac
12
Jun 6, 2014 08:18 AM
delsolo95
May 30, 2014 11:24 AM
092eg6
Aug 23, 2010 08:30 AM
P-DuBB
23
Aug 8, 2005 10:36 PM
