h22a vss problems(searched)
i just put a h22 into a 95lx. when the key is turned on the speedo reads 20mph. i unplugged the sensor and it reads the same. when the sensor is taken off the trans, the speedo reads 10mph. doesnt move while driving...seems electrical to me? im using the accord harness, any suggestions would be great.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point6 »</TD></TR><TR><TD CLASS="quote">Is it possible that the egr and speed sensor plugs are reversed.</TD></TR></TABLE>
did you do any wire changes when adding the ecu in there?
you need to do two wire swaps. maybe you mixed them up
good call, 2point6
good call, 2point6
landroveraz
Transmission & Drivetrain
Nov 19, 2009 09:33 PM
HATCHMO92
Aug 8, 2004 02:09 PM
