CEL help!
my car is a 00 EK. i was driving this morning to the dealer to get some stuff and my cel came on. i just changed my throttle cable yesterday because it became loose. it drove fine yesterday all day. just this morning the light came on. where should i start? any suggestions? also when my cable became loose everytime i press on the gas and let go it squeeks. i changed my cable and my gas pedal was now fine but it still squeeks.
pull the kick panel on the passenger side...down by your feet towards the door. under there is your ecu. look for a big green rubbery looking thing...pull the plug out of it and thats the connector you want to use. when you find that...bridge the two holes with a paper clip...make sure it is tight. then turn the key to ignition...but don't start the car. the cel will flash some pretty colors.
there should be a small plug down by your ecu. its a 2 wire i believe. anyways, you use a paperclip or wire and connect them, like a loop (hard to explain) turn the key all the way, car doesnt need to be on. the cel will flash several times.
edit: the guy above me explained it much better
this site will tel u which codes your throwing. a long blink is for the tens place and short blinks are in the ones place. ex: 1 long 2 short is 12
http://tech.hybridgarage.com/tech/codes.html
civicboy420
Aug 11, 2014 01:45 PM
romeo_f
Feb 6, 2011 08:57 AM
