Turbo timer + Sidewinder 5000 alarm - possible?
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
How would I make this work? Could I just take it to an alarm shop and have them wire it? With this setup, could I just take out the key, arm it and it still would run while the car is armed for 30-60 seconds or whatever the rate is? Sorry, I don't know anything about turbo timers.
Yes it is possible. The alarm will have to be wired in such a way that when the Turbo Timer is on, the alarm won't see ignition. The reason for this is so you can arm the alarm.
Most shops should be able to do this for you properly.
If you have troubles you can always go with a alrm that has a turbo timer built in, something like the Compustar.
http://www.compustar.org
VTEC-DA
Audio / Security / Video
Sep 17, 2002 09:47 AM
Erik_Pb_Foot
Mar 7, 2002 08:07 PM
