spark plugs....and wires...?
I was told to get NGK BKR7E11 spark plugs. and i was thinking about getting magnecor 8.5 wires. is this what i should get...i ordered a rev hard stage 2....
Thanks
Thanks
You do not really need the wires. Many of us have had serious problems with the Magencor wiles coming off while we are driving (Has happened to me 3 times, I always think I have seriously damaged the engine every time... but it is just a stupid spark plug wire)
Good choice on the plugs.
Dustin
Dustin
I used to be a strong supporter of Magnecors until I continued to have the problem Dustin described. The final straw was when I was competing in a NIRA even and it happened during a run, eliminating me
Stock wires are good enough for Chris Rado and his 9 second car, they are good enough for me
I had the EXACT same problem as the two guys above me.
In fact...some spark plugs are shorter than others so sometimes the magnecores won't even GO ON at all!
Those wires fit like ****!
I'm using MSD wires now with no problems. They "click" into place and hold on tight!!!
j_kevin_ca
Oct 12, 2004 02:23 PM
