falken tire wear
Old Jul 7, 2003 | 10:48 PM
itr1235's Avatar
Default falken tire wear
i`ve had my tires for about a year, the rear tires wears on the inside, is this a common occurence
Old Jul 7, 2003 | 10:49 PM
gary201147's Avatar
Default Re: falken tire wear (itr1235)
Under-inflated.
Old Jul 7, 2003 | 10:52 PM
itr1235's Avatar
Default Re: falken tire wear (gary201147)
it`s set at 35 psi in front and 32 out back
uNF$@#!'s Avatar
camber/toe
Old Jul 7, 2003 | 10:54 PM
itr1235's Avatar
Default Re: falken tire wear (Soup ****)
had the car aligned about 6 months ago they said it was fine, both wheels wear the same on the inside what tire pressure does the majority run?
Old Jul 11, 2003 | 09:15 AM
iperez's Avatar
I had the same problem. Check the alignment and make sure your wheels are not bent. Once I had the car properly aligned and the wheels balanced, I have had no problems at all with the wear on my Azenis.
Old Jul 11, 2003 | 02:50 PM
Haunt's Avatar
If your car is lowered, that will kill your tires on the inside. If not, I would take it to a different shop to get it aligned.
Old Jul 11, 2003 | 02:52 PM
Chris N's Avatar
Cars don't get bad inside/outside wear because of camber.
It is always toe.
Now, maybe you lowered your car so you have tons of camber, then your toe is out of spec.
You got some toe out if you have bad inside wear on a tire. Get an alignment. It would happen to any tire you have on there, not just an azenis.
Old Jul 12, 2003 | 03:24 AM
migs's Avatar
Default Re: falken tire wear (Chris N)
Toe
lolingirunarlol
Suspension & Brakes
Jul 16, 2013 06:57 PM
Fel_15
Nov 23, 2009 09:12 AM
JRizEJ6
30
Dec 1, 2006 08:33 PM
kcem1
Suspension & Brakes
Dec 15, 2005 01:48 PM
Kyles ej1
Jan 8, 2005 04:07 PM
