2 o2 sensor?
can somebody tell me where the wiring plug for this sensor is located or how do i wire it up?i have a 98 civic dx with a 00 si b16a2 ,im using a 98 ex wiring harness with the si ecu.i rewire the harness.thanks
Should come up through the floor inside the car, under dash, up by the srs module, in the middle of car. Sounds confusing because it is
But thats where mine is in my 00 si. o and it's under the carpet
i'm pretty sure you will have to wire directly from the ecu...i am in the same boat. only the si(and ex possibly) have the secondary under the car. on the dx/cx/? they are both in the engine bay. i am working with obd2b while you have obd2a...so some things may be different. search around...the info is out there.
98ekb16
Apr 13, 2011 07:39 PM
luluslc0716
Jun 8, 2008 07:27 PM
MonkeyPuzzle
Aug 19, 2005 11:54 AM
intrex
Mar 24, 2004 07:50 PM
