Hey Del Sol guys, got a question
Old Jul 7, 2003 | 07:52 PM
B16Hatchcx's Avatar
Default Hey Del Sol guys, got a question
In 94 & 95 is the Si 1.6L vtec model the B16 or is it the single cam? Thanx
Old Jul 7, 2003 | 07:55 PM
CivicNA's Avatar
Default Re: Hey Del Sol guys, got a question (B16Hatchcx)
DOHC
Old Jul 7, 2003 | 07:56 PM
EARLdaSQUIRREL's Avatar
official honda whore
if it says si then its the sohc.. but if it says vtec then its the dohc motor
Old Jul 7, 2003 | 07:59 PM
sombasol's Avatar
No, in SI's it's the d16Z6. sohc vtec 125 hp. it's called the vtec that has the b16.
Old Jul 7, 2003 | 08:00 PM
B16Hatchcx's Avatar
Default Re: (coptzer)
It says both. It says "94-95 Civic Del Sol Si 1.6L Vtec" Which one is it? Thanx
Old Jul 7, 2003 | 08:04 PM
sombasol's Avatar
Default Re: (B16Hatchcx)
it's the sohc, it's still a vtec engine it just isn't the b16. the actual title of the b16 del sol is vtec even though the engine in the si is also a vtec engine. The one your looking at is the SOHC though, I have an SI sitting in my driveway.
Old Jul 7, 2003 | 08:06 PM
B16Hatchcx's Avatar
Default Re: (sombasol)
Thanx for your info.
Old Jul 7, 2003 | 08:15 PM
quik1's Avatar
The si badging is different in ontario than california it still could be a b16.
Old Jul 7, 2003 | 08:30 PM
whoDAT's Avatar
Default Re: Hey Del Sol guys, got a question (CivicNA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicNA &raquo;</TD></TR><TR><TD CLASS="quote">DOHC</TD></TR></TABLE>
you even said it with confidence
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quik1 &raquo;</TD></TR><TR><TD CLASS="quote">The si badging is different in ontario than california it still could be a b16.</TD></TR></TABLE>
i think the canadians call the twin cam version Si-R...i think...
Old Jul 7, 2003 | 10:20 PM
Jedi_Sol's Avatar
Default Re: Hey Del Sol guys, got a question (whoDAT)
couldnt he just check the engine code on the engine itself? also check the redline, the si d16z6 has a 7200 redline, the b16 has a 8200 (something like that) redline.
if the badging says "dohc vtec" on the side and the rear trunk, then it's the b16. but you cant just base it on that cuz sometimes ppl take the badging off.
Old Jul 7, 2003 | 11:00 PM
clm's Avatar
clm
Default Re: Hey Del Sol guys, got a question (Jedi_Sol)
Check the block and/or the VIN. The Si SOHC will have "EH6" and the VTEC DOHC will have "EG2."
Old Jul 11, 2003 | 11:06 AM
TnEG2
Guest
Posts: n/a
S = 1.5L sohc!
SI = 1.6L sohc!
VTEC = 1.6L dohc!
ALL YEARs!
Old Jul 11, 2003 | 11:11 AM
mph6563's Avatar
Default Re: Hey Del Sol guys, got a question (theFURY.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by theFURY. &raquo;</TD></TR><TR><TD CLASS="quote">
S = 1.5L sohc!
SI = 1.6L sohc!
VTEC = 1.6L dohc!
ALL YEARs!</TD></TR></TABLE>
Close, but not quite. Let's try again with the S.
S = 1.5L SOHC (93-95), 1.6L SOHC (96+)
Si = 1.6L SOHC VTEC (all years)
VTEC = 1.6L DOHC VTEC (all years)
Old Jul 11, 2003 | 11:32 AM
sombasol's Avatar
Default Re: Hey Del Sol guys, got a question (mph6563)
in Canada the civic model names are different but not Del Sol. If it is an SI and it hasn't had a swap then it's a D16Z6.
Old Jul 11, 2003 | 11:36 AM
clm's Avatar
clm
Default Re: Hey Del Sol guys, got a question (sombasol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sombasol &raquo;</TD></TR><TR><TD CLASS="quote"> If it is an SI and it hasn't had a swap then it's a D16Z6. </TD></TR></TABLE>
Or a D16Y8 if it's a '96 or '97.
Old Jul 11, 2003 | 11:59 AM
day1si's Avatar
Quote, originally posted by theFURY. »
S = 1.5L sohc!
SI = 1.6L sohc!
VTEC = 1.6L dohc!
ALL YEARs!
_______
Closer but not 100%
93 there was no DOHC VTEC
so 94-97 DOHC
Old Jul 11, 2003 | 01:09 PM
mph6563's Avatar
Default Re: Hey Del Sol guys, got a question (day1si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by day1si &raquo;</TD></TR><TR><TD CLASS="quote">Quote, originally posted by theFURY. »
Obviously, I meant "all years in which a del Sol VTEC existed." After all, there was no Si in, say, 1776 either. Doesn't make sense to talk about the engine in a car that doesn't exist!
Old Jul 11, 2003 | 01:19 PM
stevecockrill's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mph6563 &raquo;</TD></TR><TR><TD CLASS="quote">
Sweet, another **** del Sol owner!!
Steve
Old Jul 11, 2003 | 02:15 PM
mph6563's Avatar
Default Re: Hey Del Sol guys, got a question (stevecockrill)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stevecockrill &raquo;</TD></TR><TR><TD CLASS="quote">
Me? ****? Surely you jest!
ulieq
Oct 8, 2010 03:21 PM
b16crxSivtec
Jun 7, 2005 04:08 PM
1MeaNDeLsOL
Jul 24, 2003 06:10 PM
816d16
16
Feb 19, 2003 08:19 PM
Sterling
12
Jul 17, 2002 06:12 AM
