Camber Kit
Old Jul 7, 2003 | 07:11 PM
Accord2K1's Avatar
New User
Default Camber Kit
Is it necessary to get a front AND rear camber kit after lowering? I got my car lowered w/ H&R Sports and Tokico Illuminas about 4 months ago. The ride is much better, but the car tends to stray off path from time to time. Lately I noticed the top of my front tires kinda point inward. The back tires look normal, but there may be a difference I dont notice. Is it best to get both kits or just one for the front or just one for the rear?
Old Jul 7, 2003 | 07:55 PM
accordfreak's Avatar
Default Re: Camber Kit (Accord2K1)
get an alignment and see where your camber is at..
if the front is THAT noticeable.. you're probably 2 degrees off or so..
Old Jul 7, 2003 | 09:08 PM
After_Burner's Avatar
Default Re: Camber Kit (accordfreak)
hmm..sorry to drift off alil but i have a question, my camber is pretty bad! plenty of positive camber, do u know of any camber kits out there that will correct, maybe, down to -4 to -5degrees?? just a solid #...and yeah, camber is that bad!
Old Jul 8, 2003 | 12:49 PM
iam7head's Avatar
Default Re: Camber Kit (After_Burner)
do you now the different between toe and camber??
Old Jul 8, 2003 | 02:33 PM
spankey167's Avatar
Default Re: Camber Kit (iam7head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">do you now the different between toe and camber??
I DO! I DO! hahah Well back to topic... Just go get an alignment done. A lot of times its just the toe that eats your tires away, not necessarily your camber. So get your specs and find out whats wrong and work from there.
Old Jul 8, 2003 | 09:06 PM
Default Re: Camber Kit ([167]spankey)
cool deal! sorry for stealing ur thunder!!
but that makes sense!!
iam7head!! obviously, theres a difference, i just dont know which part does which! but, please...enlighten me!
Old Jul 11, 2003 | 06:00 PM
soccerstudj's Avatar
depends on what the alignment shop tells you... you might be able to swing with getting the back or front done...
2n-chilli
Suspension & Brakes
Apr 14, 2011 06:24 PM
HyRev
Suspension & Brakes
Aug 20, 2008 06:19 PM
89MA70
Suspension & Brakes
Aug 11, 2008 01:01 PM
SL!M
17
Feb 27, 2005 04:47 AM
SMC Integra
Jul 30, 2003 01:49 PM
