CRAZY Shaking After Swap! Please hlep!
Old Jul 7, 2003 | 06:30 PM
Blaze45's Avatar
Brrraaaap!
Default CRAZY Shaking After Swap! Please hlep!
http://www.hasport.com/News/Ar...s.htm
in that article it says to remove some metal 0 from the hub, I didnt and my car shakes so bad that my CD player wont play. Is this normal for a B20 swap? It feels as tho the axles are binding the more I accelerate. When I brake, the shaking almost stops, (theres still a lil shaking, nothing compared to accelerating and crusing) what could it be????
thanks
Blaze
Old Jul 7, 2003 | 07:24 PM
smokey2.0's Avatar
Default Re: CRAZY Shaking After Swap! Please hlep! (Blaze45)
the hub dust shield, will not make your car shake like yours is doing. what i think is doing it, is the rear tranny bracket that holds the tranny mount to the rear cross member! do you remember massaging the lip of the rear cross member, so that the bracket won't touch it. if you forgot to do this, the car will shake like there is no tomorrow! if you did bend the lip, go back and recheck that you bendt it to the point that the bracket is not touching the rear cross member! good luck
Old Jul 7, 2003 | 08:56 PM
Blaze45's Avatar
Brrraaaap!
Default Re: CRAZY Shaking After Swap! Please hlep! (smokey2.0)
I forgot to add, what would cause my axles to bind like they do? They bind when I turn cornors. I'll check the rear tranny mount.
thanks,
Blaze
Old Jul 7, 2003 | 09:08 PM
smokey2.0's Avatar
blaze, what year axles are you using? i remember using a 91 passenger side axle on my 88 crx, and i didn't have any problems with the axle binding without removing the dust seal on the hub!
Old Jul 8, 2003 | 01:16 PM
Blaze45's Avatar
Brrraaaap!
Im using 90-93 teg axles, I dont know what year cause I bought em used.
Blaze
Old Jul 9, 2003 | 03:34 AM
Blaze45's Avatar
Brrraaaap!
HELP! anyone please!
Blaze
Old Jul 9, 2003 | 06:57 AM
rioninja's Avatar
If you didnt remove the dust rings from the hubs, then obviously thats your problem right there. Thats causing all of your problems.
Also, what intermediate shaft did you use? did you get it with the axles?
Old Jul 9, 2003 | 07:07 AM
1st-hybrid's Avatar
Did you bang out the space for the alternator? That will cause some noise under acceleration too.
Old Jul 9, 2003 | 07:21 AM
Audipwr1's Avatar
Default Re: CRAZY Shaking After Swap! Please hlep! (1st-hybrid)
my vote is for the hub rings bro
Old Jul 9, 2003 | 07:39 AM
1st-hybrid's Avatar
Default Re: CRAZY Shaking After Swap! Please hlep! (Audipwr1)
I never took mine out, and never experienced any issues because of them.
Old Jul 9, 2003 | 07:41 AM
raene's Avatar
Yes, remove the hub rings... I tried to get my car to run without removing them, and it didn't even want to get out of the garage, the axles were binding so badly. Two hours later and it was smooth as buttah.
Old Jul 9, 2003 | 07:53 AM
1st-hybrid's Avatar
Default Re: CRAZY Shaking After Swap! Please hlep! (raene)
Wow I guess I lucked out. I went over 500 miles with them in on my old axles.
I took them off with my new set though to see if there is a difference.
Old Jul 9, 2003 | 08:40 AM
CimorelliCRX's Avatar
Wha are the hub rings, i have d series, but just wonderng just to know..
Old Jul 9, 2003 | 10:39 AM
Blaze45's Avatar
Brrraaaap!
Default Re: CRAZY Shaking After Swap! Please hlep! (CimorelliCRX)
Yes someone please post actually pcitures of a hubring in your hand and show where they came from! I cannot get any type of ring out of my hub after bending a crowbar (very tip and it was just a lil still non the less.).... raene said he just pulled his out with his hand!!! Thanks for everyones help. BTW 90-93 teg axles and int. shaft as well as removed dust ring from axles.
thanks
Blaze
Old Jul 9, 2003 | 11:10 AM
keithv's Avatar
#2.
Old Jul 9, 2003 | 11:27 AM
raene's Avatar
I was exaggerating when I said I used my hand, I'm not THAT strong I actually used a very small prybar or a screwdriver... can't remember which. And yes, it's #2 on the picture there.
You want a pic of someone holding it in their hand? Here's my hand:
As you can see the dust ring goes into the back of the hub/knuckle assembly:
Old Jul 9, 2003 | 11:36 AM
raene's Avatar
Just 'cause I'm such a nice guy, here's the same graphic with some editing, the dust ring is the highlighted portion:
Old Jul 9, 2003 | 11:37 AM
Malgerus's Avatar
Check for rings on the axle. My axles were too stiff too, and I had to pull it apart and take the rings off.
Old Jul 9, 2003 | 01:43 PM
Blaze45's Avatar
Brrraaaap!
Default Re: CRAZY Shaking After Swap! Please hlep! (Mr. S)
Well IM very stoaked that my car is acually running code free (cept for 14 easy fix) but I was able to get my car out of limp mode. THE B20 HAULS NUTTS! I bruned rubber im 4th grear! WOOOO HOOOOO! Dude I almost need to go drive it again, cept the clutch cable bracket I ghetto fab'd from my D15 is giving out, so Im gonna have to get a new one. YEHA~!~! Im gonna rip the suspension apart again tommrow and rip that stupid ring out! Thanks everybody!!!!!!
Blaze
Old Jul 9, 2003 | 02:18 PM
raene's Avatar
Woohoo, it's working again How did you fix the no-start problem? I never heard...
Old Jul 9, 2003 | 03:35 PM
Rob!'s Avatar
i had a shaking problem after my swap as well but i did take the dust rings out....if you stil have the shaking problem after then try it could be your intermediate shaft cuz i had the wrong one and when i would make right hand turns it would shake real bad..i doubt its ur problem...good luck tho man. congrats on the swap
Rob
e jay one
12
Nov 3, 2006 07:16 AM
GEIJIN
Oct 8, 2006 11:21 PM
FastReligion
28
Jun 2, 2006 06:55 PM
DaiJekBok
Jul 21, 2002 04:31 PM
