lightened flywheel good or bad idea for 1989 civic si
i would buy a lightned flywheel instead of lightening a stock one. while you are at it, get a 90-00 d series flywheel. that way you can get a larger clutch, they are a little bit cheaper too.
I think 8lbs is a little too light. I went with 12 lbs for my B16A, and I like it very much. Faster than stock, but easy to live with as a daily driver.
I wouldnt run a lightened stock flywheel with ANY aftermarket clutch. All that extra force from a strong clutch can break that fw like its nothing. I know that 3-4 lbs isnt alot but the machining process can sometimes weaken the fw causing it to have alot of stress points. I would get an aftermarket one if i was to get one. For a daily driver i wouldnt go any lighter than 10lbs...and id say that 12lbs would probably be the best. Also a scatter shield wouldnt be a bad idea. Good luck
Sean
Sean
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Artful Dodger »</TD></TR><TR><TD CLASS="quote">if you're doing a lot of daily driving it could get anoying, your revs will drop really fast. You'll have to shift quick all the time or have a rouch ride</TD></TR></TABLE>
YES, my car isnt a daily driver so its not so bad...but i would hate to have one on my beater(gsr)...revs drop so fast in my crx that it actually kills the motor sometimes when i come to a stop(idle drops to low for the motor to keep running)...
...i dont really care for it...but i got mine dirt cheap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skontkanen »</TD></TR><TR><TD CLASS="quote">What do you guys think lightened flywheel, good or bad? and if good, how light?</TD></TR></TABLE>
to do it the right way, i would take the entire rotating assembly to a shop that's done this before. have them balance the assembly and then ask 'em how much you should lighten the flywheel. that way the rotating assembly doesn't get all wacked under heavy load...i.e. racing...
ps...you'll have to bring EVERYTHING that's in the rotating assembly, including the flywheel bolts...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skontkanen »</TD></TR><TR><TD CLASS="quote">how about flywheel lightened 3-4 lbs with stronger pressure plate and kevlar clutch for $430 canadian.
good idea?
is this through a shop? i'm sure people here would be interested...
good idea?
DR-JEKL
Oct 14, 2005 03:48 PM
