Tips on installing fiberglass hatch for EG civics.
Old Jul 7, 2003 | 05:51 PM
J2turbo21's Avatar
Default Tips on installing fiberglass hatch for EG civics.
Any of you guys have tips for installing a fiberglass hatch on a 92 civic.It was already pre-drilled for the mount on the bottom,anything else i should and or need to do?
Old Aug 4, 2003 | 02:04 AM
J2turbo21's Avatar
Default Re: Tips on installing fiberglass hatch for EG civics. (J2turbo21)
Anyone?Im gonna try putting it on tuesday.
Old Aug 4, 2003 | 03:19 AM
DaveF's Avatar
how are you going to mount your window back there? are you using a lexan piece or just the stock window?
Old Aug 4, 2003 | 11:06 AM
nickwilmot's Avatar
Could you post some pics of it before and after you install it? That would really help me out as well.
Thanks
Old Aug 4, 2003 | 12:37 PM
slowdx's Avatar
Default Re: (nickwilmot)
yea i cant really help you but please do tak elotf of pics and maybe do a mini write up.....
Old Aug 4, 2003 | 01:13 PM
J2turbo21's Avatar
Default Re: Tips on installing fiberglass hatch for EG civics. (2.2Lcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.2Lcivic &raquo;</TD></TR><TR><TD CLASS="quote">how are you going to mount your window back there? are you using a lexan piece or just the stock window?</TD></TR></TABLE>
Im using the stock window.
Old Aug 4, 2003 | 01:20 PM
GSRswapandslow
Guest
Posts: n/a
just the tail gate, right?
where did you get it? mmrusa???
does it fit well??
TAKE SOME PICS Y0!!
Old Aug 4, 2003 | 04:29 PM
J2turbo21's Avatar
Default Re: (GSRswapandbanned)
Yea its the tail gate,i'll try to take some pictures.It was already pre drilled cause i got it used so im just gonna copy what I think he did As for the window i think i'll tight it with a bungy cord or something.
Old Aug 5, 2003 | 03:17 AM
DaveF's Avatar
Default Re: (J2turbo21)
sparco usa makes those spring clip things. ive seen people take out the struts to hold up the window and use that hole to fasten the spring clips to. than mount the other part of it on the body.
Old Aug 6, 2003 | 09:22 PM
J2turbo21's Avatar
Default Re: (2.2Lcivic)
Hmm i'll have to look into that but for now im just gonna use some bungy cords to hold it down.I got it mounted and it doesnt fit like stock but i made it look good.I had to re-drill the holes because of that.Sorry i didnt get any pictures.Thanks everyone.
Old Aug 9, 2003 | 05:05 PM
GSRswapandslow
Guest
Posts: n/a
bump
Old Aug 9, 2003 | 07:16 PM
nickwilmot's Avatar
I would like to see some pics???
Old Aug 9, 2003 | 07:25 PM
J2turbo21's Avatar
I'll try to get some pics up.But i must say it was easier since it had holes from the old owner.I did have to drill the wholes wider so the hatch would be side to side,that way i can make sure its not to far on one side.
Old Aug 9, 2003 | 08:54 PM
pro1342's Avatar
I tossed the factory hinges and used dzus fasteners (5) to hold it in place, and fabbed some spacers so the gap between the tailgate and body were even all the way around.
Old Aug 9, 2003 | 09:11 PM
J2turbo21's Avatar
Default Re: Tips on installing fiberglass hatch for EG civics. (pro1342)
To hold the tailgate closed i just used a strap and tightend it down.I'm happy with the results and next year im gonna go fiberglass and front with lexan.
melovesboost
Oct 15, 2021 12:32 PM
johnjw
Dec 26, 2013 04:00 PM
integranator
Aug 30, 2007 05:38 PM
myke
Jan 19, 2005 02:56 PM
travis
16
Apr 20, 2003 07:12 AM
