aftermarket speedometer install??
i want to put together a custom gauge cluster and i'm wondering how do you install an aftermarket speedometer??? it doesn't look like any of them run off of a cable driven type system...anyon have knowledge of these???
well i have electronic VSS alrready that ihad hooked up to my GSR cluster, however the b series electronic VSS wont fit in my car because when i had it, i had a GSR swap as well with aftermarket mounts...now my stock d15/mounts wont allow it do fit..
damn...maybe a d series 92+ will work.
talk to a member on here - Driven
he's done what you want to do (i think)
check it out
https://honda-tech.com/zerothread?id=502804
check it out
https://honda-tech.com/zerothread?id=505901
I got rid of my stock cluster for a few reasons:
1. stock tach didn't rev high enough
2. stock cluster was becoming useless as I replaced all the information it was displaying (short of speed and fuel level)
3. the mess of wires behind the cluster was irritating and extremely messy.
aftermarket, civic, cluster, clusters, crx, custom, honda, install, installing, put, spedometer, speedometer, stock, system, tech, wire
