Dumb open door buzzer keeps going off...
Old Jul 7, 2003 | 04:23 PM
90civichbsi's Avatar
Default Dumb open door buzzer keeps going off...
I was wondering if this has happened to anyone else. My door buzzer and door open light come on whenever i hit bumps on the road even though the door is shut and will not open. It only goes off for the passenger side. It will go away if i open and shut the door but only comes back later when i hit another bump
what could be causing this? bad hinges? loose relay connection?
any help would be appreciated
Old Jul 7, 2003 | 07:07 PM
neutron91's Avatar
Default Re: Dumb open door buzzer keeps going off... (90civichbsi)
is your car lowered?... im guessing it is... ive had a similar problem with my hatch light... it will come on if i hit a pretty good bump and i can just open the hatch and close it again and it goes away... it got so annoying i just disconnected it... my dome light and buzzer used to not come on for the drivers side so i took the little L shaped switch off and cleaned off the metal connectors and screwed it back on and it worked fine... maybe that would help in your case also
Old Jul 7, 2003 | 10:56 PM
Default Re: Dumb open door buzzer keeps going off... (neutron89)
yes its lowered. just got tiens... mebe the stiffer springs made it get worse
hrmm ill try that tommorrow.. anyone else?
GarySeven123
Feb 16, 2013 05:21 AM
creed86
Paint and Body
Dec 12, 2010 06:15 AM
draperj09
May 14, 2008 08:01 PM
powerls
Mar 12, 2004 08:19 AM
Seedc2
Mar 13, 2003 03:24 PM
