HF Ecu question...
Old Jul 7, 2003 | 04:23 PM
Turbo Powa's Avatar
Default HF Ecu question...
Is the HF ecu the same as an SI? If not, what is the difference between the two?
Old Jul 7, 2003 | 04:37 PM
Stupid Ass's Avatar
Default Re: HF Ecu question... (Panda EK)
Its an MPFI Ecu... but I believe it is programmed for fuel mileage and stuff as to where the S is more for performance... but you can always use it as a temp. if your Si ECU dies.
Old Jul 7, 2003 | 05:12 PM
Turbo Powa's Avatar
Default Re: HF Ecu question... (MooreVTEC)
whats the difference performance wise?
Old Jul 7, 2003 | 05:15 PM
Timmah!!'s Avatar
Well. there is a 5500 RPM fuel cutoff, and the fuel maps are for a small 8 valve motor with a tiny IM, and throtle bodie. Plus it will be loking for an EGR valve. You could use it, but I think it will throw a code.
Old Jul 7, 2003 | 05:27 PM
Turbo Powa's Avatar
Default Re: HF Ecu question... (azroth)
so for a MPFI swap I should go with the Si ecu huh? What other ecus can I use?
Old Jul 7, 2003 | 05:29 PM
Malgerus's Avatar
OBD-O Integra (will run really rich, and if you do do this you'd want 88-89)
Old Jul 7, 2003 | 05:30 PM
Turbo Powa's Avatar
Default Re: HF Ecu question... (Mr. S)
so then I should just get a Si ecu?
Old Jul 7, 2003 | 05:56 PM
Timmah!!'s Avatar
get a 90-91 Si ECU. It has the best fuel maps. Sould go for anywhere between 50-100 bux. I think I PMed you about 2 weeks ago about trading some of your audio equipment for my 89 Si ecu, once i get my OBD1 swap done. But you are gonna probobly want a 90-91.
Old Jul 7, 2003 | 09:10 PM
Turbo Powa's Avatar
not a problem. I'd love to do the trade but I need this stuff ASAP.
Sampsonite987
10
Jan 10, 2020 04:08 AM
88crxdxfastwhip
Feb 1, 2006 06:28 PM
joey1320
43
Nov 15, 2002 12:47 PM
BeEfiEBuNz
Nov 7, 2002 04:32 PM
89hondarex
Jan 29, 2002 05:54 PM
90, 91, ecu, hf, si
