Front crossmember
Old Jul 29, 2001 | 06:48 PM
Tbone's Avatar
Default Front crossmember
Has any one upgraded to a z10 or a place racing unit?(or any others)
If you have could you please post pics, prices and where you got it.
I have allready cut mine to fit my Kooks header but my new SMSP header comes out to far on the bottom and I am not willing to trim mine anymore. Also has anyone measured how much room they gained for the downtubes? Thanks
Old Jul 29, 2001 | 07:25 PM
pagong's Avatar
Default Re: Front crossmember (Tbone)
I have a place racing crossmember and i paid 150 shipped for it! sorry no pics yet. it really frees up some space in there. look at thepartstrader or go to resource.crx.org site, thats where i got mine.
Old Jul 30, 2001 | 12:23 AM
JDM_DOHC_SiR's Avatar
New User
Z10 All the way You will have a **** load of room just like an EG..As for Place.. Gil kind of does schisty work once and a while so I'm kind of burn out on his stuff ...you'll ahve to make the call on his products
Old Jul 30, 2001 | 05:31 PM
Red Civic T's Avatar
New User
Default Re: Front crossmember (JDM_DOHC_SiR)
That was the only way I could fit my DC 4:1 header, and now there is a ton of space!!!!Something you will not be used to with 4G Civic....
Old Jul 30, 2001 | 06:44 PM
Tbone's Avatar
Default Re: Front crossmember (Red Civic T)
pics please, and price
Old Jul 31, 2001 | 09:48 AM
nomorecrx's Avatar
New User
what the hell is a kooks header? i have heard about it, but never seen it or know anyone with it. where do you get it from? the place cross member clears up plenty of space. it is a cross member, it is almost impossible to f that up. z-10...top notch products. what is your ground clearance like red civic t with the dc 4-1 header? shouldn't be good. i had the mugen header and banged that thing to hell. it had no clearance...about 1 inch tops
Old Jul 31, 2001 | 07:28 PM
New User
Default Re: Front crossmember (nomorecrx)
Ground clearance SUCKS!!!And I have Eibach supposedly ProKit but seems like it is about 2 1/2 inches lower which looks good but not good for around DC streets, plus I weigh 210 lbs......
Old Aug 3, 2001 | 07:52 AM
Full-Race Geoff's Avatar
Default z10 crossmember
Thanks for looking at our products.
As far as the radius arm kit goes, our kit is quite a bit different than the place kit. I personally know of three people who bought the place kits and the kits did not even come close to "bolting on". They had to be drilled/grinded/bent to fit. Also, the added clearance is still minimal, as the crossmember is still in the oem location, it is just smaller (and flexier)
Our kit actually moves the crossmember forwards about 3 inches, moving it between the tow hooks and stock crossmember location. It is a twin parallel tube design (for breif info on why visit http://ferrari.colowatch.com/php/showthreaded.php?Cat=&Board=ENDYN_Tech&Number=2338 4&page=&view=&sb=&o
and gives you 5 3/8" of clearance off the block.
The real benefit of our kit really comes from the adjustability of the suspension and the fact that you get rid of the steel radius arms and the sloppy rubber bushings. We replace the factory radius rods and rubber bushings with cnc machined 6061 t6 rods, and steel rod ends. This not only is a slop free design, but allows for fully adjustable caster. Also we have the option for you to run the smaller 92-95 civic radiators, freeing up even more space. I think there is something else cool but i cant remember right now. If you have any other questions, just respond, or email me. I hope this helps
Old Aug 3, 2001 | 02:30 PM
New User
Default Re: z10 crossmember (z10 geoff)
Cool to have an option, but the PlaceRacing unit worked out very well on my 91 Civic EX. I had to get this because of lack of space for DC 4:1 header with stock crossmember. Now I have more space than I am used to, and quite happy.It does not seem as strong as the stock unit but I think it should work out fine, or at least has so far......
rnomad
May 15, 2011 09:41 AM
Flexin_B18
Oct 10, 2005 06:30 PM
integerkgsr
13
Mar 26, 2005 08:41 PM
CA6VTEC
Mar 31, 2004 07:28 AM
XxDemonxX
Jan 18, 2003 10:59 PM
