civic si / crx tranny?
Old Jul 7, 2003 | 10:26 AM
skontkanen's Avatar
Default civic si / crx tranny?
will a 1989 crx tranny fit in my 1989 civic si, what parts do i need?
Old Jul 7, 2003 | 10:46 AM
slowpokesi's Avatar
Default Re: civic si / crx tranny? (skontkanen)
yes it will, it will bolt on,
Old Jul 7, 2003 | 11:10 AM
skontkanen's Avatar
Default Re: civic si / crx tranny? (slowpokesi)
i heard something about using the crx clutch and pressure plate instead of the si, because the splines were diffenent, is this true?
Old Jul 7, 2003 | 11:12 AM
blah13's Avatar
Nope, 89 to 89 is the same, if you swapped years you may have issues. Direct swap.
Old Jul 7, 2003 | 12:17 PM
IamVtec's Avatar
what they both said.
Old Jul 7, 2003 | 12:24 PM
skontkanen's Avatar
Default Re: civic si / crx tranny? (Full Throttle EF)
same or better gear ratios?
Old Jul 7, 2003 | 01:44 PM
skontkanen's Avatar
anyone?
Old Jul 7, 2003 | 06:00 PM
skontkanen's Avatar
can anyone tell me if the ratios are the same in a 1989 crx tranny as they are in a 1989 civic si tranny?
Old Jul 7, 2003 | 06:25 PM
the DR.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skontkanen &raquo;</TD></TR><TR><TD CLASS="quote">can anyone tell me if the ratios are the same in a 1989 crx tranny as they are in a 1989 civic si tranny?</TD></TR></TABLE>
If the crx is an si also, then yes, they're the same.
Old Jul 7, 2003 | 09:50 PM
JonGP4's Avatar
Default Re: civic si / crx tranny? (SlicedBread)
dude its the EXACT same drive tran just a different body on the car.
Old Jul 8, 2003 | 12:09 AM
Vinceg99's Avatar
Default Re: civic si / crx tranny? (JonGP4)
Still havent answered what model the CRX is....Is it an Si or a DX or an HF?? If its the Si they are the same exact trans as many people have said if its the DX its the same except the final drive is different if its the HF then its completely different gears.
Old Jul 8, 2003 | 07:13 AM
skontkanen's Avatar
Default Re: civic si / crx tranny? (Vinceg99)
not sure, the tranny just has a tag on it that says 1989 crx, how do i tell which one it is from?
Old Jul 9, 2003 | 01:59 PM
skontkanen's Avatar
anyone know ho to determine the crx si tranny over the base crx tranny?
Old Jul 9, 2003 | 02:32 PM
Vinceg99's Avatar
Look at the numbers that are on the tag on the tranny then come on here do a search for the tranny codes and you will be all set. Si trannies are L3 than some numbers I forgot how exactly they are but it has been covered so if you did search you will find out about them.
Old Jul 9, 2003 | 02:57 PM
IamVtec's Avatar
crx si trannys should have PL3/3000 stamped above the fill plug(tranny fluid fill plug). and HF/DX/STD have PL3/A000 or PL3/A100.
Old Jul 10, 2003 | 08:50 AM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Full Throttle EF &raquo;</TD></TR><TR><TD CLASS="quote">crx si trannys should have PL3/3000 stamped above the fill plug(tranny fluid fill plug). and HF/DX/STD have PL3/A000 or PL3/A100.</TD></TR></TABLE>another Honda myth - these numbers do not indicate what gears are inside - these are casting numbers for the case and have to do with the different size bearings - some Si's will have the smaller bearings and some have the larger bearings - i have Si's that say A000, 3000 and 9000 - have ZC's that say 3000 - have DX's that says A000 and 3000 - learned the hard way, bought a PL3/3000 that the guy claimed was Si and turned out to be DX
Old Jul 10, 2003 | 09:50 AM
skontkanen's Avatar
Default Re: civic si / crx tranny? (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">another Honda myth - these numbers do not indicate what gears are inside - these are casting numbers for the case and have to do with the different size bearings - some Si's will have the smaller bearings and some have the larger bearings - i have Si's that say A000, 3000 and 9000 - have ZC's that say 3000 - have DX's that says A000 and 3000 - learned the hard way, bought a PL3/3000 that the guy claimed was Si and turned out to be DX</TD></TR></TABLE>
so do you know how to tell then?
Old Jul 10, 2003 | 11:46 AM
blah13's Avatar
Theres a way you can tell by turning the shaft 10 times and looking to see where the diff ends up, but I cant find the damn site....
Edit : I have it saved but dont know the site....heres how you do it.
Put the tranny in 1st gear.
Rotate the shaft till the diff is at 12 o' clock.
Rotate the shaft 10 full rotations clockwise.
Si = diff at the bottom left, between 7-8 o' clock.
DX = diff at the top left, between 10-11 o' clock.
HF = diff at the top right, around 2 o' clock.
temp
Jul 19, 2004 04:29 PM
mamaboy
Jan 31, 2004 09:08 PM
red civic standard
Oct 14, 2002 07:14 AM
crxjake
Sep 5, 2002 04:16 PM
