Just did a compression test-- now here's my plan...
Old Jul 7, 2003 | 08:55 AM
92TEGsrSC's Avatar
Default Just did a compression test-- now here's my plan...
My 94 Integra GSR has 160K miles on it and I was a little worried about puttin' my JRSC onto it... I was considering a full rebiuld w/ forged internals, or even buying a sleeved block (because it seemed I'd be spending the money anyway) although I only intend to push 8lbs on the blower... Everybody's been telling me to get a compression test and that will tell me what type of condition my GSR is in...
Well, I went to a friend's house yesturday and did a compression test-- 240 in every cylinder! All my friend are telling me (correct me if I'm wrong) that 240 in every cylinder is really good and I shouldn't need to rebuild.
I was actually kinda surprised because I thought I'd read on honda-tech before that I should expect around 200- 205. I dunno-- maybe I was reading something else? Anyway, I'm not gonna do a full rebuild or get a new block... this is my new plan-- Please tell me what you think.
New timing belt
New oil pump
New water pump
Walbro 255 high pressure fuel pump
LHT's Intercooler
Kamikaze header w/ carsound cat
hondata (probably s200b) tuned well (probably from boosted hybrid)
contemplating larger injectors--- not sure if my boost level requires it
The car already has:
Apexi WS exhaust
ACT stage II racing clutch (less than 30K Miles on it)
ITR tranny w/ LSD (less than 40K miles on it)
Well, that's the plan guys-- let me know what you think... I will have the money together in the next couple weeks to purchase most of these things so any flaws in my plan need to be found now.
Thanks in Advance.
Zack
Old Jul 7, 2003 | 05:23 PM
92TEGsrSC's Avatar
Default Re: Just did a compression test-- now here's my plan... (92TEGsrSC)
ttt
Old Jul 7, 2003 | 05:48 PM
turbolshatch's Avatar
your comprssion seams really good. you should be alright by doing the second plan
Old Jul 8, 2003 | 09:05 PM
92TEGsrSC's Avatar
contemplating taking the LHT Intercooler-- a 1300$ mod off that list because I don't plan on upgrading and I could put that money toward a new block if I blow the one I have due to heat--- which I personally do not think will be a problem @ 8lbs of boost
Old Jul 8, 2003 | 09:25 PM
ThunderThigh's Avatar
200ish is for LS engines cause of their lower compression pistons. are you a aggressive driver at all? that sounds really good.
Old Jul 8, 2003 | 10:05 PM
92TEGsrSC's Avatar
Default Re: Just did a compression test-- now here's my plan... (ThunderThigh)
don't know how comfortable I am building an LSV-tec... and even if I was-- the CRVTEC seems like it'd be the real way to make some power
Old Jul 11, 2003 | 09:32 PM
92TEGsrSC's Avatar
keeping in mind that I will not be upgrading and could have that money sitting aside to put toward a new block if I blow mine (which I shouldn't because I'm only runnin' 8lbs).
Does anyone think I'm making a bad decision by excluding the LHT performance intercooler???
Old Jul 11, 2003 | 09:46 PM
Blowensi's Avatar
Default Re: (92TEGsrSC)
umm i have a friend at 10 psi he blew his block and one of the blades in the jrsc chipped so he had to rebuild both id tell you to just get the jrsc water injection its cheaper and very useful.
Old Jul 11, 2003 | 09:58 PM
92TEGsrSC's Avatar
what was his tuning?
Old Jul 12, 2003 | 05:16 PM
Cole D's Avatar
240 wow that's amazing I have a 94 gsr and my compression was 195,195,190,195 do a leak down that's the real test
Chris
Old Jul 12, 2003 | 05:42 PM
mskibbz-T's Avatar
Default Re: Just did a compression test-- now here's my plan... (chriscoleman102)
Throw the JRSC on and get some real engine management system... Hondata would be ideal since you are OBD1, cheap and effective
Old Jul 12, 2003 | 07:12 PM
92TEGsrSC's Avatar
how do you do a leakdown test?
06BlackSi #45
Honda Civic (2006 - 2015)
Nov 22, 2009 06:55 AM
SPOON_FED_DC_2
Apr 6, 2005 09:19 PM
Chubz
Jun 27, 2002 05:18 PM
joeg26er
Feb 1, 2002 08:42 PM
