what fuel pressure shoul i run
Old Jul 6, 2003 | 11:01 PM
jdmcx's Avatar
Default what fuel pressure shoul i run
i am having some fuel problems
my set up is ls block ctr pistons
2 layer head gasket
gsr head with a little clean up so about 12.6:1 compression
i have a b&m FPR, vafc and 255lph fuel pump
i am wondering what fuel presure i should have it at i just changed the plugs to ngk zfr7f-11 and i gapped them at .035 last night i ran the car hard to see how it felt with all the new stuff and it pulled fine
this morning i checked the plugs and they were white so i am thinking i am not running enough fuel the gauge says about 50 psi my a/f ration gauge stays in the orange and green
just wanted to know what you guys think any help would be great
thank
Old Jul 7, 2003 | 05:38 AM
jdmcx's Avatar
Default Re: what fuel pressure shoul i run (jdmcx)
bump
Old Jul 7, 2003 | 02:36 PM
ce's Avatar
ce
get it to a dyno and tune it..Only way to find out..Continue like that and you might mess it up..Just my 0.02
Old Jul 8, 2003 | 07:36 AM
JoHnFoRcE's Avatar
DYNO N TUNE IT N SEE WHAT POERE UR CAR MAKES THEN KEEP IT ON SPECS
Old Jul 8, 2003 | 09:12 AM
AzG35's Avatar
Sounds like you might need bigger injectors. Thats a good amount of compression. I would dyno it and see where its at. An A/F gauge (non-wideband) will not be accurate, so don't trust that.
Old Jul 8, 2003 | 04:27 PM
jdmcx's Avatar
Default Re: what fuel pressure shoul i run (AzSi22)
thanks for all the replies any body have any rc 310 injectors for sale
or would hondata solve my problem
BodyKits NW
Feb 4, 2007 08:10 AM
turbod16y7vtec
Dec 5, 2004 08:39 AM
91SIR
Apr 11, 2004 06:29 PM
JDM EG2
Apr 26, 2003 11:20 PM
GQ 05YellowEVO8
Nov 9, 2001 05:59 PM
