Air conditioner problem
Old Jul 6, 2003 | 09:00 PM
FREAKquency04's Avatar
Default Air conditioner problem
my air conditioning is not really getting cold enough. its not the freon because we jes had put some on my last tune up which was a month ago. when i took it in fer an oil change they said the R134A needs to be worked on. my question is what the hell is the R134???
Old Jul 6, 2003 | 09:12 PM
iam7head's Avatar
Default Re: Air conditioner problem (AcCorDH22ARaCeR)
r134 is the type of the feron, older honda got f12 aka pricy pos
Old Jul 6, 2003 | 09:54 PM
GimpyAccord's Avatar
Default Re: Air conditioner problem (iam7head)
r12 you mean.. i assume that was a typo
Old Jul 7, 2003 | 04:40 AM
YeuEmMaiMai's Avatar
what year is your car?
1994 and newer all require r134a
Old Jul 7, 2003 | 07:27 PM
White 99's Avatar
sounds like you've got a freon leak. they can run dye through the system and find it, usually fairly simple test.
Old Jul 8, 2003 | 03:47 PM
Default Re: Air conditioner problem (GimpyAccord)
nopes it specifically says R134A
Old Jul 9, 2003 | 05:03 AM
OK here is what you can do yourself
1. Go to AutoZone or your favorite auto store and by the following
1. a recharge kit with leak detector dye (usually yellow or red colored)
2. start car and put a/c on MAX settings (I'd leave a window open)
3. add leak detector dye
4. look for leaks
5. once leak is found take car to A/C center and have them remove all R134a
6. If you can, make repairs otherwise have above shop do it (I's recommend HONDA dealer). Make sure that you replace receiver dryer, and I would go as far as to replace all O-Rings. (honda sells them as a kit)
7. place system on a vacume for at least 8 hours but I would go for 12 (this ensures that the system is purged of any air and or debris.
8. add proper amount of charge and make sure that there is leak detector dye in it.
9. check for leaks and repair (if the system held the vacume, it should not leak)
chances are it's gonna be either an o-ring or a hose that is leaking
Old Jul 9, 2003 | 02:30 PM
Spooch69's Avatar
I don't know if this will help but I put too much freon in my car and that made the A/C less cooler. I just released some of the freon back out and then I got coldness.
FD3S
Feb 20, 2006 11:38 PM
djseek
13
Jul 9, 2005 09:42 PM
integra dave
Jun 2, 2004 01:20 PM
Skippy
Jul 24, 2002 10:32 AM
abeaujuin
May 7, 2002 02:58 PM
