questions on lighter flywheel
Old Jul 6, 2003 | 08:55 PM
MikeSarr_GSR's Avatar
Default questions on lighter flywheel
I have a GSR with an ITR block, nice car but too pretty... far from a drag racer at 14.85 @ 93.6mph as my best time with stock IHE, Tranny, clutch, cams. I have an ITR flywheel in it and am changing up to a CM 7.5 with a segmented kevlar disk, stock ITR PP and TOB.
I have Azenis now and the motor is running very well, everything same other than
the clutch, will I see any benefit in acceleration? My 60' was 2.27" and 9.5" 1/8 mile on potenza RE730s. Just trying to get an idea if I should expect any added benefit performance/acceleration wise. While I am in there I will do ES mount inserts and shifter bushings
Old Jul 7, 2003 | 03:13 PM
jeremyEG's Avatar
Default Re: questions on lighter flywheel (MikeSarr_GSR)
you might drop a tenth or two, then again you might gain a tenth or two.
its really too hard to tell, you'll just have to go and find out.
post what happens, im curious if just a flywheel will have much affect.
Old Jul 7, 2003 | 03:44 PM
Default Re: questions on lighter flywheel (jeremyEG)
wont be for 2-3 weeks or so for the clutch to brake in, after that I will let you know...
Old Jul 7, 2003 | 04:02 PM
DaveF's Avatar
for a street car i wouldnt go lower than a 12lb flywheel
Old Jul 7, 2003 | 09:07 PM
Default Re: questions on lighter flywheel (2.2Lcivic)
point taken. I like driving my friend's NA ITR with the comptech flywheel. this one should give me a similar feel, thanks though.
Old Jul 8, 2003 | 05:58 PM
EleanoR's Avatar
Comptech aluminum FW 6.75 lbs = YUMMY
Old Jul 8, 2003 | 10:15 PM
Default Re: questions on lighter flywheel (EleanoR)
speak of the devil... UPS owns me this week
Old Jul 8, 2003 | 10:19 PM
Mr Hammond's Avatar
a/k/a Jomo
If you like accelerating quicker, then you will love it.
8lb flywheels and streetcars =
Old Jul 8, 2003 | 10:25 PM
Default Re: questions on lighter flywheel (Mr Milano)
thanks paisan'
I love it. If you take the ups shipping weights of all my clutch parts
even though there were other items in the boxes:
3 of 3
1.) ITR TOB 1lb
2.) ITR pressure plate 15lbs (big box with some oil filters and paper in it)
3.) kevlar clutch disk and flywheel 11lbs.
what is actually spinning its safe to say is less than 24lbs... considering the
pressure plate is also fixed to the flywheel... thats not too bad
clutch goes in on friday with my ES bushings and mount inserts. Damn...
that breakin period will be a real pain... labor of love for sure...
stock pressure plate for GSR seems much heavier than the ITR unit.
id estmate like 20lbs by itself, disk is about 5 lbs and the flywheel on
GSR stock is 18 lbs... holy monkeys batman... so lets say... 38-40lbs?
EgAd
Old Jul 10, 2003 | 02:43 AM
SoCal ITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Milano &raquo;</TD></TR><TR><TD CLASS="quote">If you like accelerating quicker, then you will love it.
8lb flywheels and streetcars = </TD></TR></TABLE>
I have a lightweight fly, but you don't really accelerate any faster. Rev matching is great though!
Old Jul 10, 2003 | 08:00 AM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: questions on lighter flywheel (SoCal ITR)
Umm you are kidding right?
Old Jul 10, 2003 | 11:53 AM
SoCal ITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Milano &raquo;</TD></TR><TR><TD CLASS="quote">Umm you are kidding right?</TD></TR></TABLE>
No. The only benefit that I have gotten out of mine is better rev matching. The car does not accelerate faster.
Old Jul 10, 2003 | 03:30 PM
Mr Hammond's Avatar
a/k/a Jomo
Well I doubt I'm the only one. 1st, 2nd and 3rd gear pull noticable quicker. 4th and 5th do but not as noticable since the weight savings formula goes down with each gear.
Old Jul 10, 2003 | 04:00 PM
any gas milage benefits?
Old Jul 10, 2003 | 11:11 PM
SoCal ITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Milano &raquo;</TD></TR><TR><TD CLASS="quote">Well I doubt I'm the only one. 1st, 2nd and 3rd gear pull noticable quicker. 4th and 5th do but not as noticable since the weight savings formula goes down with each gear.</TD></TR></TABLE>
Could be different on your car. I've tracked mine several times since and my times are all identicle.
Old Jul 11, 2003 | 12:15 PM
clutch is finally installed and I begin the 500mi 4K rpm break in period... love what I feel so far
Old Jul 11, 2003 | 12:36 PM
AussieK24's Avatar
Is that all you've changed? If so cool, before and after direct comparo
Old Jul 11, 2003 | 04:55 PM
Austin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EleanoR &raquo;</TD></TR><TR><TD CLASS="quote">Comptech aluminum FW 6.75 lbs = YUMMY </TD></TR></TABLE>
7.3 lbs...trust me, I know...I weighted 3 of them on a very accurate shipping scale
Old Jul 13, 2003 | 02:22 AM
Default Re: questions on lighter flywheel (Austin)
its kinda funny considering the weight issue.
the shipping package weight from my CM disk and flywheel from
ITR 132 was 11lbs. the shipping weight from Bert-O at Gettel for the
ITR PP was 15lbs with an oil filter and a few mouse pads and all that
packaging in a big box. that is all that spins... so at worst case scenario
my clutch weighs a total of 26 lbs, best case 25lbs. Considering ITR
flywheel is 15lbs, PP and disk like 17 we are talking a GT of 32 for a
stock ITR clutch. GSR... however... yikes. PP is like 22, disk is same
like 1-2 and flywheel is 18, so call it 42lbs... woah. I had an ITR flywheel
in there with a factory parted clutch probably at about 38lbs total.
Dropping 13lbs in clutch weight... holy *****. I am totally in love with this
clutch I have 220miles on it already Being a good little boy...
man do my RPMs ever rise quicker on that GSR tranny with that weight
savings The highest RPM ive seen on moderate throttle is
6200, I let the rpms fall back down before shifting smoothly though.
I can tell you its a ton more responsive. My motor is USDM ITR shortblock
with GSR head/ported IM(secondary runner ports reshaped), ITR valvetrain
and GSR cams. I cant wait to dyno/run a baseline 1/4mi and see how it does.
Last time I was at the track was in late 11/02. My car has broken in a bit more
and its been running very well as of late. I cant wait till 501miles!
VTEC+WOT+25lb (-15lbs) clutch = me
spintboy
Dec 19, 2007 02:48 PM
tallblondkid
31
Nov 5, 2004 07:36 AM
94lsboost
Oct 30, 2003 01:28 AM
Big Teggie
Sep 9, 2001 02:51 PM
