b16 head porting
Old Jul 10, 2003 | 06:12 PM
RACERDAN's Avatar
Default b16 head porting
I am wanting to know about epoxy under the valve seat 1/4 or so to smooth the flow to the valve seat do the pros do this? I know it helps flow figures but is it worth the extra work?
Old Jul 10, 2003 | 06:37 PM
MAX_CFM's Avatar
Default Re: b16 head porting (RACERDAN)
nope
Old Jul 11, 2003 | 07:23 AM
HEAD's Avatar
I wouldn't do it. I would rather hurt the flow a little then have the epoxy come out
I use a epoxy called Pigs Putty seems to work very well but I wouldn't use anything that sees street duty
Old Jul 12, 2003 | 06:56 AM
Fkned2003's Avatar
I use epoxy all the time ,mostly on drag and circle track motors , if the head is preped right u will have no problem with fall out in a reasonable amount of time .I've seen it last for 3-4 seasons in a set of heads with no signs of letting go.
Old Jul 12, 2003 | 02:57 PM
HEAD's Avatar
Default Re: b16 head porting (Fkned2003)
your right if prepped right it should stay, I think it has gotten a bad rap from people whom don't know proper procedure, but in a race motor you can keep a better eye on it starting to come out because you are frequently taking it apart unlike a street motor, agree?
Old Jul 13, 2003 | 02:29 AM
Fkned2003's Avatar
Default Re: b16 head porting (HEAD)
was ageeing with you all the time dave, sorry if it didnt come out that way.Only used glue a couple of times on street myself.
eh2_Trav
Engine Machining & Assembly
Feb 26, 2017 09:14 AM
jdmarsh
12
Mar 28, 2012 05:45 AM
ludesleep
11
Dec 11, 2004 03:36 PM
gimpykid
Aug 5, 2004 05:42 AM
