would upgrading my oil and water pumps hurt my engine?
Old Jul 6, 2003 | 07:15 PM
madhatter07's Avatar
Default would upgrading my oil and water pumps hurt my engine?
hey guys i am gonna be putting my B18B1 into my car next weekend and im gonna do the routine maintenence aka timing belt, oil pump, water pump. Within a year of putting the engine in i plan on going to an LS/Vtec setup and i know your supposed to use a Vtec oild pump on a vtec head but my question is would it hurt my B18B1 engine to put a type r oild and water pump on it now without the vtec head? is there such a thing as too much water and oil flow. I dont really want to have to buy another set of pumps when i do the head swap
Old Jul 6, 2003 | 07:43 PM
EF_LSVtec's Avatar
Default Re: would upgrading my oil and water pumps hurt my engine? (madhatter07)
you dont need vtec pumps to do lsvtec...LS pumps=LS timing belt, Vtec pumps=Vtec timing belt.
Old Jul 7, 2003 | 04:28 AM
Default Re: would upgrading my oil and water pumps hurt my engine? (EF_LSVtec)
so i should just stick with the LS pumps?
Old Jul 7, 2003 | 01:21 PM
AzG35's Avatar
The pump that determines what belt you use is the water pump. You can use a GSR/ITR oil pump without any modifications. If you use a GSR/ITR/B16a water pump, you must you a GSR timing belt. If you use a LS water pump, you must use a LS timing belt. This is for an LSVtec though. I am not sure about a straight LS. I would think it would probably work too, but not sure.
Old Jul 7, 2003 | 05:15 PM
granada_sun's Avatar
nah vtec timing belts have different number of teeth than LS does.....
but its a good idea to upgrade if high revs are planned, where vtec pumps flow higher volume than LS.
Old Jul 7, 2003 | 08:10 PM
Default Re: (granada_sun)
ok so just for the sake of clarification it is
A) Possible to put an itr oil pump and water pump on an LS engine
B) Safe to put the two afformentioned peices of equipment on a relatively stock LS engine
Old Jul 7, 2003 | 08:19 PM
yes. ITR water and oil pumps will BOTH fit on ls engine.
With those you will need b18c timing belt.
Old Jul 7, 2003 | 08:31 PM
ok cool, hats off to you sir
Old Jul 7, 2003 | 08:42 PM
Default Re: (madhatter07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madhatter07 &raquo;</TD></TR><TR><TD CLASS="quote">ok cool, hats off to you sir </TD></TR></TABLE>
thirsk66
10
May 22, 2013 02:26 PM
Justintegra
Apr 20, 2008 12:46 PM
1slowcrx
Nov 17, 2004 03:24 PM
ILOVEGIRLS
Sep 30, 2002 11:07 PM
