Please Read my Rebuild Parts list - Am I missing something??
Old Jul 6, 2003 | 10:01 AM
FredoSP's Avatar
Default Please Read my Rebuild Parts list - Am I missing something??
Okay the Motor is out (I will make another thread and post pics). Im putting together a list of parts for the rebuild. Please look it over and tell me what you think and/or if Im missing something.
Thanks - Fred
Okay the Motor has 72k on it so right off the bat ..
1. Honda OEM Timing Belt
2. OEM Honda Oil Pump
3. OEM Honda Water pump
4. OEM Honda Exhaust Manifold Gasket
5. Hondata Intake Manifold gasket
6. OEM Honda Alternator Belt, A/C belt and P/S Belt (Yeah Im keeping these)
7. OEM Honda Headgasket
Since the tranny and clutch are out, should I ...
8. Resurface the flywheel ?? (it has about 23K on it)
9. Crower Rods
10. Arias 9:1 CR pistons Flat top?? I think they come with rings
11. ARP Headstuds
12. (All) OEM Honda Bearings
13. new Motor Mount Inserts, where, who, what etc??
14. The crank will be getting Micro-polished
15. I want to steam-coat the engine so it will look nice and new
16. The Block will be getting sleeved, I don't know of should go with Darton or GE .. that's something I have to figure out.
Old Jul 6, 2003 | 11:05 AM
Boostfed's Avatar
New User
Default Re: Please Read my Rebuild Parts list - Am I missing something?? (FredoSP)
Darton or RS Machine. I won't even get into Golden Eagle
Old Jul 6, 2003 | 11:11 AM
Danger's Avatar
Default Re: Please Read my Rebuild Parts list - Am I missing something?? (Boostfed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed &raquo;</TD></TR><TR><TD CLASS="quote">Darton or RS Machine. I won't even get into Golden Eagle </TD></TR></TABLE>
i have to agree with boostfed . me and my friends had some blocks sent to GE and on a few of those blocks the sleeves had dropped . i have yet to use my sleeved block but im thinking of changing the sleeves to Darton or RS before i install it
Old Jul 6, 2003 | 03:41 PM
FredoSP's Avatar
Default Re: Please Read my Rebuild Parts list - Am I missing something?? (JonnyDanger)
ok guys ,, yeah Im going to call RS Machine in Cali to see the prices and shipping, etc. Thanks.
Bump for comments
Old Jul 6, 2003 | 04:29 PM
93LSivic's Avatar
Darton all the way, aaaaahem. Dude your like 1.5 hours from me...save yourself the shipping and bring your block to me for the sleeving.
For oem parts I would add a belt tensioner and spring---real good insurance.
Get either a b20, or itr oil pump...they are basically the same and have higher pressure then LS and b16.
No need to resurface flywheel unless your replacing the clutch disc. Replace clutch disc while out, they are cheap enough.
Arias pistons are pretty loud in terms of piston slap. I would do wiseco or even ross. I dont think 9:1 are flattops either, i may be wrong.
Motor mounts. You can get the 3M window weld stuff. I hear it works well and is relavtively inexpensive if you split the cost with another cause supposedly one tube does 2 complete sets of mounts.
Umm, thats all I can think of. Oh, might as well have the head checked for flatness while its off. You also have to choose what hg too---I suggest cometic HP with Darton blocks.
Old Jul 6, 2003 | 05:32 PM
tony1's Avatar
Default Re: Please Read my Rebuild Parts list - Am I missing something?? (93LSivic)
9:1 pistons in a b16 actually are almost flat tops because of the small stroke of the b16. Sounds like you have an easy decision on the sleeving, Dan is right around the corner from you. I'd take it to him and get the darton sleeves
Old Jul 6, 2003 | 05:38 PM
93LSivic's Avatar
Default Re: Please Read my Rebuild Parts list - Am I missing something?? (tony1)
Thanks for the recommendation Tony.
I didnt put 2 + 2 together when looking at his series motor on the pistons.
Old Jul 6, 2003 | 05:40 PM
FredoSP's Avatar
thanks guys ,, I might go with Wesco Pistons .. argz the choices
piscorpio
Feb 10, 2009 05:27 PM
KevronsEG
Jan 6, 2004 08:38 AM
alpha
Nov 13, 2003 04:50 PM
