hey guys wondering about Headgasket and clearance.....
i have b20z with crower 404's with spring/Retainers and i'm going to run a OEM headgasket but i'm goning to make it a one layer but taking the top two off. this will make my compression 10:0:1. do i ahve to worry about hitting my valves? thansk guys any help woudl be great. just to let you know it has skunk2IM and bored TB cam gears, dc header, j's Intake, chipped ECU,clutch, ctr n1 pulley, arp head bolts, its in my eg hatch
Modified by CIV616 at 6:04 PM 7/6/2003
http://www.c-speedracing.com/h...y.php
Hope that helps. There should be a few threads here as well.
When I did my motor I found the piston to hit the head on its points. (the highest corners on the piston)
It only hit with the headgasket off. There is .007 clearance in my motor from piston to head with an entire oem headgasket in.
rich7777
Sep 13, 2012 08:43 AM
zigs
Jun 21, 2003 04:15 PM
