MF2 Wiring question
Simply stated, I wired the MF-2 unit and it's not workin properly... the yellow wire is supposed to go the negative coil.. BTW 99 Accord 4cyl F-Max kit... however if you have the MSD BTM then you cant wire the MF2 to the negative coil also otherwise it will fry the MF2... so I need an RPM signal.. where do i get one from? I did some research b/c i thought that i could use the crank sensor but hte Accords that generation only have a countershaft sensor and a crank positioning sensor not a crank speed sensor... i need somethin that is goin to detect rpms by the thousand range bc that is how you tune the mf2... TIA for any ideas/help.... and tell me which wire also plz it is
u can use the tach wire going to ur msd box if u have one or..... well i have a diagram at my house that can help you however if in class right now. so i cant get if. If u still need help just reply.... and ill go look at my diagrams
