Are these 9.0:1 compresssion pistons?
Old Jul 5, 2003 | 09:16 AM
reaction360's Avatar
Default Are these 9.0:1 compresssion pistons?
I recently purchased these pistons from another H-T member. They were supposed to be 9:1 B16a JE pistons. They looked fine and everything, but after looking at my buddy's supposed JE 9:1 pistons, our's look totally different. here's a picture of mine, my buddy's are alot more dished, where as mine are more just flattened. thanks
https://honda-tech.com/zerothread?id=531159
Old Jul 5, 2003 | 09:26 AM
hatchback19's Avatar
Default Re: Are these 9.0:1 compresssion pistons? (reaction360)
They might be SRP, JE and SRP are almost identical companies, SRP is alittle lower grade I belive.
Old Jul 5, 2003 | 09:36 AM
Default Re: Are these 9.0:1 compresssion pistons? (hatchback19)
well regardless of make, shouldn't motor specific and compression specific pistons have the same top-end design? whether it be flat or dished?
Old Jul 5, 2003 | 09:38 AM
I don't belive so, since there are any number of differant designs to make the same compression. Look under the piston, above the pin and look at the stamp.
Old Jul 5, 2003 | 10:17 AM
Boostfed's Avatar
New User
Find out the dome displacement on the pistons and punch that calculation into the calculator on http://www.c-speedracing.com
Old Jul 5, 2003 | 10:22 AM
tony1's Avatar
Default Re: Are these 9.0:1 compresssion pistons? (Boostfed)
If i remember right, 9:1 compression pistons in a b16 block are almost flat top. If your buddy got some that are dished, then they're probably 9:1 pistons for a gsr, which will yield a very low compresion on the b16. Around 8:1 maybe??
Old Jul 5, 2003 | 10:25 AM
ekb18c's Avatar
Default Re: Are these 9.0:1 compresssion pistons? (tony1)
Remember, same pistons may yield different compressons on differnt motors because of the combustion chambers of the heads.
Old Jul 5, 2003 | 10:36 AM
Default Re: Are these 9.0:1 compresssion pistons? (ekb18c)
ok. both me n my buddy have B16A's. JE's and are both supposed to be 9:1, but look different. Also, does bore play a role? his are 84mm. mine are 81mm.
Old Jul 5, 2003 | 10:51 AM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reaction360 &raquo;</TD></TR><TR><TD CLASS="quote">ok. both me n my buddy have B16A's. JE's and are both supposed to be 9:1, but look different. Also, does bore play a role? his are 84mm. mine are 81mm.</TD></TR></TABLE>
Absolutely! On an 81mm bore you would have a dome displacement of -.6cc and on an 84mm is would be - 3.88ccs
Old Jul 5, 2003 | 10:58 AM
bingo. thanks for everyone's info. now i can rest easy.
Old Jul 5, 2003 | 11:05 AM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reaction360 &raquo;</TD></TR><TR><TD CLASS="quote">bingo. thanks for everyone's info. now i can rest easy. </TD></TR></TABLE>
hotimportcrx
Sep 15, 2005 10:13 PM
tslex
Oct 20, 2004 11:00 AM
808b18c1boosted
Apr 23, 2004 12:30 PM
grimple1
Mar 20, 2004 12:25 PM
allmotorhatch
Aug 31, 2002 09:47 PM
