Intercooler on an all-motor
Old Jul 5, 2003 | 07:30 AM
f@sth@tch89's Avatar
Default Intercooler on an all-motor
I wanted to know if this is possible and a good idea. Trying to have the air cold all the time. Would it be legal? I would have my scoop on the left side..ran to the intercool..which would be connected to the tb/intake manifold. good or bad idea?
Old Jul 5, 2003 | 07:48 AM
AussieK24's Avatar
Default Re: Intercooler on an all-motor (fasthatch89)
You've got no way to push the air thru a cooler without a turbo/supercharger...
Old Jul 5, 2003 | 07:52 AM
4piston's Avatar
The air is already cool. An intercooler cools the heat generated by the turbo or blower. It would be more efficient to run an intake tube through your headlight or bumper. You would just be cooling air that is already cool. It would be restrictive.
Old Jul 5, 2003 | 01:12 PM
Lsos's Avatar
An intercooler works because of the temperature difference of the intake air and the ambient air. The temperature difference is there because the turbo heats the air when it compresses it. With no turbo or supercharger you have no temperature difference, and with no temperature difference all the intercooler does is restrict airflow.
Old Jul 5, 2003 | 07:21 PM
Skunk2Steve
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fasthatch89 &raquo;</TD></TR><TR><TD CLASS="quote">I wanted to know if this is possible and a good idea. Trying to have the air cold all the time. Would it be legal? I would have my scoop on the left side..ran to the intercool..which would be connected to the tb/intake manifold. good or bad idea?</TD></TR></TABLE>
Do I smell some RICE cooking on this THREAD???
Old Jul 5, 2003 | 08:46 PM
indomotor's Avatar
Default Re: Intercooler on an all-motor (Skunk2Steve)
It does work!!!My friend tried it.He made 5hp and torque all through the rpm.It would've more efficient cause my friend used a fuel pump instead a water pump.Yes it was water to air intercooler.
Old Jul 5, 2003 | 09:42 PM
4piston's Avatar
Default Re: Intercooler on an all-motor (indomotor)
ha ha
Old Jul 5, 2003 | 11:19 PM
eg_type_r93's Avatar
f off
Old Jul 6, 2003 | 12:36 AM
SuperTwinz's Avatar
This guy is joking obvivously.
Old Jul 6, 2003 | 11:53 AM
mmuller's Avatar
Mad Scientist
Default Re: Intercooler on an all-motor (Supertwinz)
does fire come out of his exhaust too?
Old Jul 6, 2003 | 12:07 PM
snowseeker's Avatar
LMAO
I once heard if you run a 150 or up shot into your oil pan you will see big gains!!
Old Jul 6, 2003 | 12:47 PM
MackSpeed-616's Avatar
Default Re: Intercooler on an all-motor (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">does fire come out of his exhaust too? </TD></TR></TABLE>
whats wrong with that? my car often flames from the exhaust.
Old Jul 6, 2003 | 01:09 PM
mmuller's Avatar
Mad Scientist
Default Re: Intercooler on an all-motor (BustaNutt-616)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BustaNutt-616 &raquo;</TD></TR><TR><TD CLASS="quote">
whats wrong with that? my car often flames from the exhaust. </TD></TR></TABLE>
your car:11.83@115mph
mmmm, supras shoot flames out of the exhaust too, high powered cars sometimes do that.
I was being ironic
Old Jul 6, 2003 | 03:35 PM
wm5holla's Avatar
get a front mount intake!<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by indomotor &raquo;</TD></TR><TR><TD CLASS="quote">It does work!!!My friend tried it.He made 5hp and torque all through the rpm.It would've more efficient cause my friend used a fuel pump instead a water pump.Yes it was water to air intercooler.</TD></TR></TABLE> TELL ME ABOUT UR FREIND
Old Jul 6, 2003 | 03:40 PM
dfoxengr's Avatar
Default Re: Intercooler on an all-motor (wm5holla)
obviously doesnt know what an IC is..
cehcivic15
32
Apr 1, 2010 11:47 AM
chadalac1712
99
Feb 25, 2007 09:18 AM
nota-ex
29
Mar 27, 2004 07:50 AM
servion
Jul 21, 2003 02:30 PM
4doorSleeper
Jan 4, 2002 10:23 PM
