turbo teg acting really weird, need help.
my cars been turboed for about 3-4 weeks now. ive put 300-400 miles on it (speedometer/odometer wasnt hooked up for the first two weeks so dont know specifically). i have a new clutch, flywheel, im boosting 7psi right now untuned with stock injectors, and i also recently found out that i have a broken axle. so this ONLY happens after i get on it a little. ill be driving normal, and you know ill get the urge to go fast so ill take it up to about 6k for a couple of gears then start to slow down. then after then, it gets REALLY WEIRD, if im going from a stop, ill rev it up and slowly let out the clutch and it will just bog, not shut off but just lunge back. then when im just cruising at like 2.5k it will like stutter, you can feel it lunge back and forth slightly. so usually when this happens if im a stop i have to rev it to like 3.5 and keep it there as i slowly let the clutch out, then it doesnt do it. i really dont know what the deal is...
-because its not tuned?
-clutch?
-flywheel?
-broken axle?
i dunno, im lost. a guy at the shop that did the work took it for a drive and he got the same thing after he got on it a little, he doesnt know yet, i thought id try here.
thanks.
ps. this ONLY happens after i get on it, everyday normal driving isnt a problem, clutch feels fine, doesnt lunge or stutter or bog or anything, only after i get on it a little????????
-clutch?
-flywheel?
-broken axle?
thanks.
right now just an fmu and drag high flow inline fuel pump, when it gets tuned with the hondata im also putting in some 450cc's
jxhxb
Oct 8, 2009 09:55 PM
