ok just blew my motor again... can an s2000 motor be transplanted???
Old Jul 4, 2003 | 07:14 PM
jansenrw's Avatar
Default ok just blew my motor again... can an s2000 motor be transplanted???
as title states, has anyone ever transplanted an s2000 into a type r????
Old Jul 4, 2003 | 07:19 PM
Tweakmeister's Avatar
Default Re: ok just blew my motor again... can an s2000 motor be transplanted??? (jansenrw)
it would be very difficult.
the s2k motor faces 90 degrees differently (rwd).
sgT's Avatar
sgT
WHatever you get i'd put money down that it blows up as well.
You guys need to invest more time in tuning BEFORE you race it. Missing races
is cheaper than replacing motors.
Old Jul 4, 2003 | 07:21 PM
jansenrw's Avatar
I heards that a company makes custom trannys to conver rwd to fwd.. The reason why I'm asking is tht I have acess to a very cheap s2000 motor (insurance crap)
machgo5go's Avatar
Default Re: ok just blew my motor again... can an s2000 motor be transplanted??? (sgT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sgT &raquo;</TD></TR><TR><TD CLASS="quote">WHatever you get i'd put money down that it blows up as well.</TD></TR></TABLE>
Buy a new car, its cheaper
Old Jul 4, 2003 | 07:22 PM
jansenrw's Avatar
hear your words of wisdom sgT but can the tranplant be done????
Old Jul 4, 2003 | 07:23 PM
jansenrw's Avatar
or can the new i-vtec from the dc5 be transplanted????
Old Jul 4, 2003 | 07:29 PM
Default Re: (jansenrw)
the answer is "why bother?"
those motors aren't less prone to "blowing up"
Old Jul 4, 2003 | 07:31 PM
jansenrw's Avatar
my motor only blew because of the builders.. I'm enquiring about my other options before I buy a new motor...
stRtypR25's Avatar
Default Re: (Tweakmeister)
all i am wondering is why do you have a turbo timer (in your sig.)
Old Jul 4, 2003 | 07:32 PM
jansenrw's Avatar
a/f ratios
Old Jul 4, 2003 | 07:38 PM
REFLUX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jansenrw &raquo;</TD></TR><TR><TD CLASS="quote">a/f ratios</TD></TR></TABLE>
no offense man....but you use your turbotimer for reading a/f ratios?????
something's wrong with that
and if you want a straight up answer with using an S2K engine in your R.....yeah it can be done
you can also put a corvette engine onto a moped with enough money too!!!
Old Jul 4, 2003 | 08:05 PM
GokuSSJ4's Avatar
is cheaper than replacing motors.</TD></TR></TABLE>
its amazing how much tuning makes a difference in a built motor . making sure that everything runs right .
tuning is always a must
Old Jul 4, 2003 | 08:06 PM
Mires's Avatar
Default Re: (REFLUX)
I would just put a new R engine back in. The s2000 engine wont give you a whole lot more performance over the R engine. When you consider that many skilled drivers have kept up with the S2000 in their R.
Old Jul 5, 2003 | 02:51 AM
MiraiZ's Avatar
Default Re: (Mires)
if you've got the money and the time, anything can be done
case in point....someone transplanted an f20c into and AE86
I've also seen a rotary engine in a AE86
and just recently, saw a Nissan Twin-turbo v-6 motor (possibly a the Fairlady Z) put into a Masarati.
All setups cost in the $60,000 range to fabricate and build
Old Jul 5, 2003 | 06:46 AM
igyloo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jansenrw &raquo;</TD></TR><TR><TD CLASS="quote">my motor only blew because of the builders.. I'm enquiring about my other options before I buy a new motor...</TD></TR></TABLE>
Old Jul 5, 2003 | 07:05 AM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: (igyloo)
C'mon now, you're answering your own questions. It blew up because of your builders and you know tuning is important. Get a new builder and tune it properly. It won't be anywhere near as unique as the S2000 engine swapped in (is that the F20C?), but if you're just using it for racing, who cars? It'll be way cheaper, easier, less-time consuming to just build a good B18C5.
Old Jul 5, 2003 | 07:21 AM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
Default Re: (sscguy)
Not to defend this guy but Apex'i markets their turbo timer as an Auto Timer. Basically its mainly a Air/Fuel Ration monitor but it has turbo timer functions. They advertise it for both N/A and F/I vehicles.
Old Jul 6, 2003 | 05:34 PM
GZR4DR's Avatar
Default Re: (Apex i ITR)
ITR motors are horizontally mounted, S2K motors are transversely mounted and rear wheel drive. Unless they make an adapater to mount a S2K motor to a B series or D series trans its not going to happen.
The amount of money to mod your car to be able to use the S2K motor will be like more than buying 2 ITR motors. BTW spoon products are a waste of money, if you want to have a fast straight line car, choose another companies products. Hell spoon doesn't even make most of their parts, they outsource everything. I look at their products as slightly better OEM parts, thats all.
Old Jul 6, 2003 | 05:48 PM
GokuSSJ4's Avatar
Default Re: (GZR4DR)
have you consider k20 , which well tune can some bolt ones can achieve with hondata 240whp
Old Jul 6, 2003 | 05:54 PM
RickV's Avatar
That isn't Dom's old motor is it?
Old Jul 7, 2003 | 04:13 PM
sgT's Avatar
sgT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Apex i ITR &raquo;</TD></TR><TR><TD CLASS="quote">Not to defend this guy but Apex'i markets their turbo timer as an Auto Timer. Basically its mainly a Air/Fuel Ration monitor but it has turbo timer functions. They advertise it for both N/A and F/I vehicles.</TD></TR></TABLE>
Any A/F meter that uses the stock sensor is completely useless
Old Jul 7, 2003 | 04:57 PM
Big Phat R's Avatar
Does the fact that the S2000 spins the other way make a difference to you?
Old Jul 7, 2003 | 05:01 PM
Chris N's Avatar
Default Re: ok just blew my motor again... can an s2000 motor be transplanted??? (Big Phat R)
It would cost big big BIG BIG money.
You just can't throw it in, the entire engine bay and a good deal of the underside of the car would have to be completely reworked, all custom, all big money.
What's the point? There are plenty of other big power-making, viable options.
Old Jul 7, 2003 | 05:06 PM
Hooch'n's Avatar
Default Re: ok just blew my motor again... can an s2000 motor be transplanted??? (Chris N)
wow
njcgsr
Mar 30, 2008 10:35 AM
civichick457
Dec 17, 2004 06:52 AM
RustyRex
Nov 18, 2004 11:19 AM
