bad idle problems
My JDM ITR motor has a weird idle. it idles and sounds like its a v8 with cams. Sprayed down all the vacuum lines and gasket areas and no leak. Im getting no check engine lights. I cleaned out the IACV. Compression test numbers are perfect. I adjusted the idle screw and no difference. Performance wise there are no problems, the idle will get low and the ecu will catch it and raise it,repeating the process over and over, the whole time it will not idle over 1000 rpms. Im stumped
